Could someone please identify this aircraft for me.
HI, This aircraft is Qantas Airbus A330-300
Manufacturer Serial Number (MSN)----->564
Age 14.9 Years
current registration---->VH-QPC
Test registration------>F-WWYQ
Production Site---->Toulouse (TLS)
Airframe Status--->Active
Enjoy, cheers !!
source:https://www.planespotters.net/airframe/Airbus/A330/VH-QPC-Qantas/ZQNhDG
7$\begingroup$ I can't see any way you could work out from the original image it's this particular A330? Also the photo and data just seems to be copied from here, you should cite your source: planespotters.net/airframe/Airbus/A330/VH-QPC-Qantas/ZQNhDG $\endgroup$– PeterJSep 21, 2018 at 14:53
1$\begingroup$ @PeterJ, definitely better to cite the source, but he was right... that's a Qantas' bird ;-) Look at the red under the tail on the fuselage and the reg. number under the left wing. $\endgroup$ Sep 21, 2018 at 16:03
$\begingroup$ @PeterJ, the one in the question. :-) $\endgroup$ Sep 21, 2018 at 16:18
1$\begingroup$ I concede that it is a Qantas jet. But Qantas owns 28 A330's. How did you determine that it was this specific aircraft? $\endgroup$– TomMcWSep 21, 2018 at 18:31
5$\begingroup$ While waiting for al Maghraby to explain, I'm guessing that he drew his conclusion from the registration number under the left wing. Enlarging this reveals that it is VH- + three letters, first is O or Q, second P or B, third C or G. The only matches in Qantas's registrations are QPC and QPG. Don't know why it couldn't be VH-QPG. $\endgroup$ Sep 21, 2018 at 21:19
