The Wikipedia page on stall strips states that AA-1 Yankee airplanes used stall strips to avoid tip stalls (and spins) because wing washout couldn't be used.
So my question is: can two stall strips placed on each tapered wing (tapered wings love tip stalling) eliminate the need for a washout?
Secondly, what does it mean for a wing to have a washout of 6°? Does it mean the angle of incidence at the root is 6x greater than the tip?
    $\begingroup$ Your second question might already be answered here $\endgroup$
    – Pondlife
    Commented Sep 15, 2018 at 22:50
Rectangular wings can get away without washout because that planform tends to have favourable root to tip stall progression as a characteristic of the rectangular shape.
The stall strips aren't really to change the root to tip stall behaviour as a substitute for washout; their job is to generate a local flow separation, just prior to the natural stall, who's turbulent flow can be felt through the airframe and at the elevator while the rest of the wing is still unstalled. That's why they are just short sections in front of the outer parts of the horizontal tail, so that the burble they produce will be felt through the controls well before the rest of the wing lets go.
The Yankee had a NACA 64-416 laminar airfoil which had an abrupt stall and very little natural pre-stall buffet - helped by the strips. Later variants got a revised airfoil with a drooped nose to make the stall itself more gentle, but they still retained the strips to provide the pre-stall buffet.
Many years ago I flew a Yankee that was in a flying club I was in, and it was considered a demanding airplane. The stall strips made it a bit less dangerous than without, but it still took careful speed control when landing. If you got too slow it would start to sink and pulling a bit more pitch had no effect. It had a reputation as a very "hot" airplane for something with only 108 HP.
On a tapered wing, you would be adding stall strips for the same reason as the Yankee's wing, near the root forward of the outer end of the horizontal tail, to provide a distinct pre-stall warning buffet. If your tapered wing had no washout but had the strips, all that would happen is you would get a pre-stall buffet that wouldn't be there without them, but then when you get to the wing's stalling AOA the whole thing goes at once because it's still a tapered wing with no washout.
Some designers get some of the benefit of washout without twisting the wing by varying the airfoil section itself from root to tip.
  • $\begingroup$ Many thanks!....One question: if vortex generators are put on the outer wing(e.g 1/3 of a wing), to keep airflow attached as the root of a tapered wing stalls, does this cancel out the need for washout? The reason am asking is 'cos, am trying to design an ultralight wing:which is tapered and I want to avoid washout for the sake of building simplicity. $\endgroup$ Commented Sep 16, 2018 at 6:35
  • $\begingroup$ Yes VGs are used for that reason. Leading edge VGs raise the stalling AOA by several degrees, maybe a 3rd of what you get with a leading edge slat. I call them "poor man's slats". The VGs have to be placed at a sweet spot that is just forward of the separation point at stalling AOA. You'll have to determine the location and spacing by experimentation. $\endgroup$
    Commented Sep 16, 2018 at 12:29
6 degrees of washout means the angle of incidence is 6 degrees lower at the tip than the wing root, causing the wing root to stall first. Leading edge slats serve the same function, especially in combination with trailing edge flaps near the roots.
Whether these strips would replace washout is debatable, trying to "save" an approach by pulling hard on the elevator is not. The end (literally) result is the inside wing, slower than the outside in the turn, stalls first, the plane then rolls and falls to the ground. Only immediate opposite rudder, along with relaxing the elevator, will help if you catch it in time.
This means that at wing root the angle of incidence is 6° greater than the at wing tip.
For example, if the incidence at tip is 2°, with washout of 6°, then the incidence at root is 8°, so the wing stalls and has stall disturbances much earlier at root. This helps to better preserve aileron authority.
