This question might seem strange as almost all aircraft have the air flowing over the wing in only one direction. However if you wanted to design an airfoil would have a good L/D in the forward flow direction, but would also generate lift, or at least not have excessive drag under reverse flow conditions, how would you go a about finding such an airfoil?
The Aerobie flying disc uses an airfoil that looks like a fish. The fish tail creates stability in a spinning disc, but also quite a bit of drag I believe. If stability is not a concern, I think another airfoil shape may provide less drag.
https://en.wikipedia.org/wiki/Aerobie
http://www.aerobie.narod.ru/aerobie.htm
You would copy the cross-setional shape of the frisbee plastic disc toy, which generates lift as it spins and travels through the air by using a shape which looks like the leading edge of a wing no matter which way it is pointing. a wing with two "leading edges" like this is not as efficient as a wing with a tapered trailing edge, but it works well enough to fly significant distances and provide fun for its users.
