I saw this plane many years ago:
  • Same shape and size as an commercial airliner.
  • No windows along the fuselage
  • Painted flat gray (like a naval ship)
  • Had a blue circle on its "nose" (Blue painted radome)
  • Rectangular "hump" with rounded corners on the bottom of the fuselage.
If you can identify this plane, could you please tell me the make and model and what it's used for?
UPDATE: the question has been put on hold so I will try to be more specific. I saw a plane fitting this description flying unusually low over the Chelsea neighborhood of New York City on the morning of September 11, 2001 shortly before 9:00 AM. It was flying south over 8th Avenue. I had just exited the subway station at the 23rd Street and 8th Avenue. I was walking west towards my office on 11th Avenue when I was startled by a very very loud sound directly overhead. I turned and looked up and saw this low flying plane. I have never ever seen an airplane fly that low except near an airport terminal. It was shocking and frightening. I literally thought the plane was going to land in the middle of 8th Avenue. I remember looking for smoke or visible signs of damage but it looked like it was okay. It was actually slowly and gradually descending, but then it climbed back up. There were no markings on the plane apart from the blue "bulls eye" on the "nose" (pardon my lack of knowledge about aviation. I don't know the proper terminology).
Several minutes later I was on the M23 bus when I heard an extremely loud bang, which I would assume was the first plane hitting the WTC. It was so loud that my ears were ringing for a while. I remember trying to convince myself that the sound had nothing to do with the plane because the thought was too awful. At the time, there was a lot of construction going up on west Chelsea (gentrification. high rise luxury condos being erected where transsexual prostitutes used to roam the streets). I tried to convince myself that it was from the construction. The image that came to mind was taking a steel garbage dumpster and throwing it off the top of a skyscraper.
I don't know what this plane was but it had something to do with what happened on 9/11. If only I had had a camera at the time and could have taken a picture. I need to know what this plane was and how it fits into what happened that day. This is not a joke. I realize that this is going to be controversial and some people may be upset. I want to reiterate that this is not a joke of any kind. Please do not flag this post. I need an answer to what has haunted me for 17 years. Thank you.
    $\begingroup$ Several military aircrafts are designed based on commercial aircrafts. You may refine your description as it fits at least the A330MRTT, all C135 versions, KC767, KC46 and many other listed here. Do you have an idea of which air force was operating it? what other characteristic can you provide? $\endgroup$
    – Manu H
    Commented Sep 5, 2018 at 7:06
    $\begingroup$ A photograph of the aircraft would be useful for identification as this description can match multiple types. $\endgroup$ Commented Sep 5, 2018 at 8:02
  • $\begingroup$ 2 or 4 engines? Prop or Jet? T-tail or conventional? Conventional gear or tricycle? Was it headed north or south at the time you saw it? $\endgroup$
    – FreeMan
    Commented Sep 5, 2018 at 14:28
  • $\begingroup$ I think 2 engines. It was a jet. It was headed south. $\endgroup$
    – Teddy
    Commented Sep 6, 2018 at 1:51
  • $\begingroup$ @ManuH: From the date we can rule out the Airbus and the KC-46. With two engines neither the C-135 fits the description. The rectangular hump was a phased array antenna. There are many SIGINT/ELINT versions of jets around, some of them part of black programs. This was one of them. $\endgroup$ Commented Jun 9, 2019 at 8:13
Sounds like it may have been a Boeing RC-135
(source)
No windows and a flat grey color would lend to either a cargo aircraft or a military aircraft with military being likely considering the color choice.
