As stated many times here 1, 2, 3 wings generate lift by moving air downwards. This downward air creates an equal and opposite force pushing the aircraft up.
High aspect ratio wings have a greater lift/drag ratio because they are moving large amounts of air a little bit, vs lower aspect ratio wings which move a little bit of air a lot.
Now my question is why does this matter?
When using "solid" objects to generate "lift" this doesn't matter as long as the solid object is strong enough not to break. For example the image below shows 2 different sized poles (different aspect ratios) resisting the same amount of force.
Air is not a solid, and so when high pressure is exerted against it, air will compress absorbing some of that pressure and converting it into heat and potential energy.
There is also pockets of low pressure that will form which can try to "suck" the aircaft back into it creating drag. In some cases these low pressure pockets cause the water vapor in the air to even evaporate:
Is this the reason it's more effective to move a lot of air slowly, vs a little bit of air a lot? To prevent the energy from being lost to heat conversion/ storing potential energy that your aircraft will not beneficent from as you already flew out of the area of the release?
If that is true would the same apply to water which is a non compressible liquid? Is this why we don't often see boats with "high aspect ratio" displacements of water?
  • $\begingroup$ Regarding the comparision to "high aspect ratio" boats, I submit that they do exist. Case in point: Rowing sculls, very long and narrow. (However, not for the same reasons.) Look up "hull speed" in Wikipedia for a better explanation than I am prepared to give. $\endgroup$ Sep 4, 2018 at 20:23
  • $\begingroup$ Wouldn't a boat that's very long and narrow be comparable to a plane that has a low aspect ratio (short wings longer body) design? I'll look up hull speed as you suggested $\endgroup$
    – YAHsaves
    Sep 4, 2018 at 21:42
  • $\begingroup$ Comparable, maybe... that's why I mentioned it. However, very different as well. Read up on hull speed, it is interesting if you are into this sort of thing. Cheers. $\endgroup$ Sep 4, 2018 at 21:46
    $\begingroup$ Correction: the water vapor condenses to form contrails or "clouds" around the aircraft (as in your picture), it doesn't evaporate. It's already evaporated, that's why it's water vapor in the first place. $\endgroup$
    – FreeMan
    Sep 5, 2018 at 13:32
11
No. In fact, compressibility does not really come into play until you come into ground effect or high Mach numbers.
Let's consider placing an object (why don't you try your (empty) coffee cup?) in mid-air. The moment you release it, it will rapidly accelerate downwards and eventually disassemble spontaneously. This is because air can move out of the way of the coffee cup. The only reason the cup experiences some resistance is due to the viscosity in air (very minor effect) and the inertia of the air that's in the way.
Lift generation relies almost solely on the inertia of the air. You accelerate air downwards, and due to the inertia of the air mass, you feel a force opposite of this, that is, upwards.
The reason high AR wings are more efficient at this process has to do with reducing induced drag. Specifically, it is more efficient to accelerate a large mass of air a little bit, than a little bit of air a lot. Copying from an earlier answer of mine,
The force to keep the object aloft is $$F=m_{object}g$$ The force generated by downwards momentum transfer is $$F=\dot{m}v$$ with $\dot{m}$ indicating mass flow (kilogram per second) of the air (not the mass of the object). The energy flow (power) required to impart this momentum on the airflow is $$ P=\frac{1}{2}\dot{m}v^2$$ Here we can draw an important conclusion. The power requirement is arbitrarily small, by increasing the mass flow and decreasing the downwards velocity.
This is the main reason for high AR wings: by increasing the wingspan (so, for equivalent surface, we increase the AR), we increase the amount of mass flow $\dot{m}$ affected by the wing.
