I'm looking for the correct/usual terminology for a coordinate system, that is moving with the wind.
I do calculations in a Cartesian East-North-Down (END) system. When taking wind into account I'd like to move this system with the wind and transform it back to an earth-fixed END-system afterwards. So basically, the reference point of my coordinate system isn't a point fixed on earth, but an air molecule that is blown with the wind.
Is there a common name for such a coordinate system?
Firstly, I thought of it as the "Wind-Frame", but after some investigations I conclude, that the term "Wind-Frame" is meaning a different system which is also rotated and not only moved in the plane.
So if any body knows, I'd like to hear from you.
I use this because I calculate Dubins paths and want to take wind into account. So when projecting the path of the plane on earth, you will see a trochoid, but the plane itself will fly a plain circle in its surrounding air. This eases calculations a great deal.
