In document 260B, "Minimum operational performance standards for 1090Mhz Extended Squitter", on page 47 of the pdf, in the DF18 format they have mentioned for a particular CF(code format), "non-ICAO flight address".
So I wanted to know what the difference was between ICAO and non-ICAO flight address?
  • $\begingroup$ Hello @vinas sunder, welcome to aviation.stackexchange.com. $\endgroup$
    – DeltaLima
    Aug 29, 2018 at 14:47
The use of the non-ICAO flight address field is described in the very same document, on table 2-11, page 53 of the PDF:
AA field holds another kind of address for the transmitting ADS-B Participant: a self-assigned "anonymous" address, a ground vehicle address, or a surface obstruction address.
Ground vehicles and surface or tethered obstructions want to participate in ADS-B, but they don't have ICAO aircraft addresses, so they have to have their own addresses. Since these addresses aren't centrally assigned, the CF field is used to keep them distinct: otherwise, you could have a vehicle address that conflicts with an ICAO aircraft address.
The different kinds of addresses are further described in section 2.2.5.1.1 (p 172 of the PDF).
