Where I live not many houses are built under the immediate approach/takeoff line of airports. Instead, they use the area for, say, sports fields.
Is it possible, in otherwise no-wind conditions, for a vortex/wake turbulence caused by a landing/taking-off aeroplane to dislodge a cricket bail on a nearby sports field? How close would the sports field have to be to the runway for this to possibly happen?
In the case at hand the (horizontal) distance is about 1.5 km and the plane (737?) was landing (directly overhead) some time before.
    $\begingroup$ From personal experience (used to run through an area near the approach end of a runway), I can say that they do reach the ground, but are not very strong. Don't have any experience of cricket balls, though :-( $\endgroup$
    – jamesqf
    Aug 21, 2018 at 18:52
According to the FAA vortices from the very largest planes generally do not drop vertically below 1000ft of the flight path. So, large aircraft flying less than 1000ft (300 meters) overhead have the potential of being felt on the ground.
This YouTube video shows a fatal aircraft accident after a medium sized prop airplane flew about 100ft above, and 40secs before the takeoff of a small plane. enter image description here
The FAA addresses vortex generation and avoidance in AC_90-23G.pdf and the following information encompasses some of that information. In general, pilots are told to be weary of vortexes for 5min, 5mi, and 1000ft below. The following diagram supports this generalized rule... enter image description here enter image description here
Flight tests have shown that at higher altitude the vortices from large aircraft sink at a rate of several hundred feet per minute (upto 300 fpm), slowing their descent and diminishing in strength with time and distance behind the wake-generating aircraft.
6 things determining vortex strength and behavior
1) Aircraft Speed - As the velocity of an aircraft increases, the strength of the vortices is typically reduced. That's because flying faster typically requires a lower angle-of-attack. It's also why takeoff and landing are critical times to pay attention to the flight path of large aircraft around you, because they're going relatively slow and creating large vortices.
2) Aircraft Weight - The heavier the aircraft, the more lift must be produced to sustain flight. Increased lift also increases vortex strength. The A380 below is a great example of this.
3) Angle of Attack - Higher angles of attack result in stronger vortices. You have a stronger difference between low and high pressure around the wing with a high angle of attack.
4) Wing Configuration - Clean configurations result in stronger vortices, because higher angles of attack are typically needed.
5) Proximity to Ground - When your wing is close the ground, wingtip vortices can't get as big, because as they spin around your wingtip, they impact the ground and dissipate. This is a major part of ground effect.
6) Wind - While wind doesn't change the strength of vortices produced, it does impact the way vortices affect you. Wind speed and direction determines how vortices travel and dissipate. For instance, if you have a strong crosswind, the vortices produced by airplanes will float in the direction of the wind.
The aircraft was likely flying near 250-275ft altitude
most approaches are 3deg
1.5km=4920ft
.0524 = tan(3deg)
height(ft) = dist(ft) * tan(deg)
257(ft) = 4920ft(dist) * .0524 (tan(3deg))
  • $\begingroup$ "unless the aircraft are flying less than 1000ft" well, given the data in the question, as John K says, it would have been at about 300ft. $\endgroup$
    – Federico
    Aug 20, 2018 at 20:53
The 737 would have passed over only about 3-400 ft overhead. The vortices move downward and apart, and without wind and turbulence to disrupt them they spin for quite a long time, a minute or two, although they tend to break up into segments.
On a windless day where there is actually a wind but it's only a knot or two, the vortice on the upwind side, with a wind speed = to the vortice's lateral drift rate, may end up descending straight down to the ground.
If the wicket stumps are loosely installed where a sharp blast of wind could move them around enough to make the bail fall off, that could be possible. Or, someone kicked it...
  • $\begingroup$ Thanks. About that kicking. The video evidence shows that no person (or their bat) touched the wicket. But I should say that the video is inconclusive about the ball itself (frame rate simply too low). Yet nobody (umpires, wicket-keeper, batsman) noticed/heard/saw. $\endgroup$
    – Řídící
    Aug 20, 2018 at 16:54
  • $\begingroup$ The wicket bears some resemblance to very early seismometers -- maybe a tiny earthquake? $\endgroup$
    – Zeiss Ikon
    Aug 20, 2018 at 17:07
