Since there are different dimensions of aircraft in various approach categories, I wonder what changes pilots in different aircraft have to make when following the PAPI lights. I know that 3° (for example) for one aircraft is the same for all other aircraft, but different categories might have different touchdown points when following the same glideslope due to the MEHT.
Since the PAPI is fixed, what differences are then when flying it in two different aircraft? Does the size of the aircraft change the flight path in any way? Will I always touch down at the same spot?
