I took this photo from the Wikipedia entry on afterburners. What's the circled aircraft in the background behind the Phantom?
1$\begingroup$ What museum was this photo taken at? $\endgroup$– Romeo_4808NAug 12, 2018 at 21:33
2$\begingroup$ @CarloFelicione Prague Aviation Museum I guess. I cross-reference the list of museums with both a Mig-23 (whose afterburner we are seeing) and a Saab Draken (left). $\endgroup$– PaghillectAug 12, 2018 at 21:40
2$\begingroup$ @DarthPaghius It is the Deutsches Museum (Flugwerft Schleissheim), in Munich $\endgroup$– GypaetsAug 12, 2018 at 21:59
1$\begingroup$ @DarthPaghius the large number of German registrations should be a clue, as well as the SP on the F-4 which indicates the aircraft was stationed at Spangdalem AB in Germany as part of USAFE. $\endgroup$– jwentingAug 13, 2018 at 5:17
2$\begingroup$ @jwenting It could've been the 'German planes' wing from just about any aviation museum... $\endgroup$– MastAug 13, 2018 at 5:29
1 Answer
The aircraft (I presume you mean what’s visible behind the green F-4 Phantom in the right of the photograph) appears to be a rare surviving prototype of a Dornier Do31 VTOL transport aircraft.
1$\begingroup$ Yeah that's probably it! Looks distinctive enough not be mistaken with anything else. $\endgroup$ Aug 12, 2018 at 21:39
$\begingroup$ I've seen this beast in the Deutsches Museum, Museumsinsel in Munich several times in the past. Good to see they moved it indoors. $\endgroup$– jwentingAug 13, 2018 at 5:16
5$\begingroup$ That spike projecting from the nose of that plane is rather impressive. $\endgroup$ Aug 13, 2018 at 8:06
2$\begingroup$ @MichaelKaras: first aircraft in history whose primary armament was a tusk. :-) $\endgroup$ Aug 13, 2018 at 17:35
1$\begingroup$ Seems as trying to use it would be about as deadly as a bee using it's stinger. $\endgroup$ Aug 13, 2018 at 17:39
