I watched this video of a delivery of an A350.
at 14:50 there is the sequence I'm interested in: the ground radar normally counts down the distance to the ground, but shortly after the 20 feet mark, it calls the typical "retard" to pull the levers back.
Why is it like this and not like normally at 0 feet?
  • $\begingroup$ What do you mean by "normally"? And do you mean the callout or the reduction of the thrust? $\endgroup$ Aug 12, 2018 at 16:42
    $\begingroup$ I am offended that you refer to the pilot as a typical retard. $\endgroup$ Aug 7, 2019 at 14:35
11
Normally is not 0 feet: all Airbus (maybe with the exception of the A380, that might have a longer flare) have a "Retard" call at 20ft, not at 0ft. From the A320 Flight Crew Training Manual:
As a reminder, the ”RETARD” aural alert will sound. In flare, this aural alert will occur at 20 ft, except in the case of autoland, where it occurs at 10 ft.
  • 7
    $\begingroup$ Where is the answer to the question - WHY? This statement only re-enforces what the original question stated - that the Airbus flight computer calls out to retard the throttles at 20ft. $\endgroup$
    – jwzumwalt
    Aug 12, 2018 at 15:21
  • 7
    $\begingroup$ @jwzumwalt NO. The question "why is this aircraft different?" is based on the false premise that this is the only Airbus doing it, while others have it at 0. the answer is: the premise is wrong, all do it at 20. $\endgroup$
    – Federico
    Aug 12, 2018 at 15:28
I'm no expert on this aircraft but I think it's because jet engines don't respond instantly to throttle changes because combustion is a continuous process, rather than a series of individual strokes in a piston engine.
If you just suddenly reduced the fuel input, you reduce the pressure in the combustion chamber and the flame might go out. Instead you have to do it gradually and wait for the turbine to reduce speed.
These days, the throttle just tells the engine controller what power setting the pilot would like to have, and the engine controller reduces the fuel flow at a rate that the engine can handle.
So (again, at a guess) 20 feet is how long it takes the engine to reduce power.
It depends on the airframe, but in this case, I guess Airbus test pilots determined that 20 ft AGL was the best place to retard the throttles to expedite the roundout with enough energy left to do it safely.
As a general rule, commercial and business jet aircraft are aerodynamically pretty slippery and do not slow up quickly when the thrust levers are pulled to idle. This fact is compounded when the a/c is in ground effect, which is why jets are generally flown onto the runway as opposed to flow to a stall prior to touchdown. I would guess aircraft with newer generations of high bypass engines slow up faster that low-mid bypass turbofans and turbojet powered airplanes do. Some business aircraft, for example the Embraer Phenom 300, suggest the thrust levers should be pulled to idle as the aircraft passes over the threshold markers (piano keys) prior to touching down some 750-1500 feet thereafter (by ATPL standards).
