General weather reporting for wind direction in Australian Standard the degrees in wind direction identifies where the wind is coming from.
Is it the same around the world?
Sign up to join this communityGeneral weather reporting for wind direction in Australian Standard the degrees in wind direction identifies where the wind is coming from.
Yes, it is generally used that the broadcast wind is the magnetic heading for the direction the wind is coming from. This is because standard runway numbering is magnetic direction and pilots can easily determine the most appropriate runway given the wind.
