If an applicant is an ASEL private pilot without an instrument rating, are these assumptions correct?
  1. Multi-engine dual time can be used to satisfy the 10 hours complex time requirement
  2. Cross-country time flown as a solo student pilot can be used to satisfy some of the 50 hours total cross-country required, including the long (300 mile) cross-country flight
  3. Cross-country time flown as multi-engine instruction cannot be used as cross-country PIC because the pilot was not rated in category and class
  • $\begingroup$ Welcome to aviation.SE! I reworded your question a little for clarity but if I got something wrong then please do edit it again as necessary. I also assumed you're asking about the US because you used the term ASEL; when asking about regulations or procedures, please always tell us which country you're asking about. $\endgroup$
    – Pondlife
    Aug 2, 2018 at 21:12
  • $\begingroup$ @Pondlife ASEL is not US-specific terminology $\endgroup$
    – Dan Hulme
    Aug 2, 2018 at 22:33
  • $\begingroup$ @DanHulme Thanks, I didn't know if it was or not! $\endgroup$
    – Pondlife
    Aug 2, 2018 at 22:40
Your question is slightly unclear, but I'm assuming the following:
  • You're asking about the US/FAA Part 61 requirements
  • The candidate is planning to take the CSEL checkride
  • The candidate holds a private ASEL certificate, without an instrument rating
  • The candidate has received some MEL training (you didn't say how much), but isn't yet rated for MEL
In that case, the answers are:
  1. 61.129(a)(3)(ii) requires 10hrs of instruction in a complex or turbine aircraft, but it doesn't say how many engines the aircraft has to have or what the training has to include. So using time from general MEL training is fine.
  2. The FAA has said that 'double-dipping' time from private to commercial is not allowed, therefore flight time as a solo student cannot count towards the commercial certificate (Theriault (2010) interpretation).
  3. If the pilot was receiving instruction in an aircraft that they weren't rated for then there's no way for them to log PIC time because none of the scenarios in 61.51(e) for logging PIC time apply. As you said, logging PIC as sole manipulator of the controls also requires you to be rated in the aircraft.
(This question is related.)
