A new TFR was recently published, which references the Riverside (RIS) VOR/DME.
When I look at the relevant chart in SkyVector, I don't see such a VOR in that area.
When I put the ID "RIS" into SkyVector, it takes me to an intersection outside London, UK.
PilotNav has the info, but that took a lot of searching.
How is one meant to interpret this TFR if the nav aid is so hard to find?
Why didn't they use bigger and easier NavAids like MCI or ANX, which are not far away, and clearly depicted on the charts?
Update!
After I brought this to the attention of the local offices, they canceled the TFR and issued a new one expressed in terms of the MCI VOR, which makes a lot more sense. The FAA was incredibly responsive and helpful!
    $\begingroup$ RIS was discontinued in September 2017. Maybe they just copy pasted an old TFR without checking. $\endgroup$ – fooot Jul 9 '18 at 22:26
  • $\begingroup$ Thanks @fooot. Confirmed here as well: boldmethod.com/learn-to-fly/navigation/… $\endgroup$ – abelenky Jul 10 '18 at 1:01
    $\begingroup$ This would be an good thing to call and ask them about; Kansas City Center is the responsible ARTCC. It certainly looks like the TFR is based on a decommissioned and uncharted navaid, which shouldn't be the case. $\endgroup$ – Pondlife Jul 10 '18 at 14:00
  • $\begingroup$ I sent a note to the local FSDO via their webform. I may try to contact them in other ways. $\endgroup$ – abelenky Jul 10 '18 at 14:30
    $\begingroup$ The secret service owes you one! $\endgroup$ – TomMcW Jul 10 '18 at 19:00
They didn't explicitly say it was a mistake, but I think they decided it was better to use an operational VOR.
(however, a couple weeks later, they referenced the RIS VOR again in a NOTAM.)
ForeFlight shows it on the airport at Wheeler Downtown. enter image description here
  • $\begingroup$ Garmin Pilot has it as well. But isn't the Paper Chart the authoritative source? $\endgroup$ – abelenky Jul 9 '18 at 22:29
  • $\begingroup$ Probably not anymore, actually. $\endgroup$ – Steve V. Jul 10 '18 at 20:49
