I would like to estimate the amount of time a pilot would have before a forced landing after suffering engine failure in a Bell 47-H at 1,000ft. This is for purposes of understanding a historical accident. The pilot in question ran out of fuel so the tanks were empty. Many thanks.
  • $\begingroup$ Never flew the -H, but in -G-3B, as I recall about 20 seconds, perhaps 18. Depends upon temperature, airspeed at the start, etc. $\endgroup$ – mongo Jul 3 '18 at 18:50
  • $\begingroup$ Many thanks for all answers. I'm not sure the exact starting altitude but it seems like tens of seconds is likely. The pilot did manage an autorotative landing. $\endgroup$ – RBH Jul 4 '18 at 15:05
According to this fairly recent flight test...
As we climbed for an autorotation Sean explained that the yellow line around the bubble effectively demarcates your autorotation options − you can land on anything under the line, you’d be pushing it beyond that. With the inertia of the -23 model blades and their nine-pound tip weights, the entry is smooth and unhurried, the descent at sixty knots bringing up about 1,700 fpm, and the flare stress-free − very different from the crash-bang-wallop engine-offs of the low-inertia world.
Around 1700 feet per minute in auto. The Bell 47 is known to be one of the most forgiving helicopters to autorotate, thanks to the large blades with weights on the tips... what is known as a 'high inertia' rotor system. The opposite is a 'low inertia' rotor system such as the Robinson series, which requires less power in flight, but the lighter blades don't retain nearly as much inertia in an auto, giving one less latent energy to use during the final flare, and a more slender margin of error.
On my daily commute, I used to admire a Bell 47 I'd see out doing traffic reporting duties. An article popped up in the local paper on how that particular 47 lost engine power at 2000 feet... it was fresh out of an overhaul. The 47 was landed with only a ding on one skid... no report on the damage done by the pilot to the mechanic who overhauled the engine, but I suspect it may have been more than a bent skid.
Somebody might be able to provide some actual numbers, but fwiw, you could look for a H-V curve (height-velocity) chart. I can't find one for the 47H but here's one for the 204B.
Wikipedia
It doesn't show any times, but it will show the height and forward speed combinations that should allow for a safe autorotation. Anything outside the red shaded area should be safe. The curves are created by test pilots, but are based on "minimum ability." Of course, that doesn't account for what you have below you to actually land on.
Using some basic physics, distance s, acceleration from gravity a, time t, initial velocity Vo, then:
s = Vo*t + 1/2 a * t^2
Assuming Vo was 0 (straight & level), then you have
1000 ft = 1/2 (32 ft/sec^2) * t^2
Rearranging,
t sec = square root (1000 ft *2 / 32 ft/sec^2) = or about 8 seconds.
Is that enough time to get the blades spun up for autorotation? I don't know.
  • $\begingroup$ You're assuming it would drop like a rock? $\endgroup$ – TomMcW Jul 3 '18 at 20:39
  • $\begingroup$ Yes in lieu of any other data. In MA we had a state helicopter drop like a brick into a Charles River boat house when it's rotor blades seize up a few summers ago. Several severe injuries or worse if I recall. $\endgroup$ – CrossRoads Jul 4 '18 at 1:53
  • $\begingroup$ Rotor blades seized? That sounds like no fun at all. $\endgroup$ – TomMcW Jul 4 '18 at 2:46
  • $\begingroup$ Yes, 4 dead, 2 years ago newenglandaviationhistory.com/tag/… $\endgroup$ – CrossRoads Jul 5 '18 at 3:05
  • $\begingroup$ Maybe it was longer ago - article says 1995. I had just started flying in 1994, maybe that's why I still recall it. $\endgroup$ – CrossRoads Jul 5 '18 at 3:13
