48
Airplanes are routinely launched from ocean going vessels, namely carriers.
Missiles are routinely launched from submarines.
Has an airplane ever been launched from a submarine?
From questions about what qualifies:
  • Manned or unmanned is ok, but payload mass has to approximate a least a small person
  • One way trip is ok
  • Airboat dropped in the water is ok
  • Airbreathing primary propulsion required, rocket assist for takeoff is ok
  • Wings for lift are required, control fins alone do not qualify
  • 7
    $\begingroup$ Technically a cruise missile is a disposable aircraft (jet engine and wings, if unmanned) and modern variants can be tube launched while submerged. Presumably the same could be done with a UAV. $\endgroup$ – Chris Stratton Jul 2 '18 at 21:59
  • $\begingroup$ @ChrisStratton A cruise missile as you describe would qualify if you can find one that actually comes from a sub. I've seen them from cruisers and destroyers. $\endgroup$ – Pilothead Jul 2 '18 at 23:43
    $\begingroup$ Tomohawk would be the obvious example, with both horizontal and vertical sub launch, as well as surface ships. $\endgroup$ – Chris Stratton Jul 3 '18 at 0:05
  • 7
    $\begingroup$ This list, en.wikipedia.org/wiki/List_of_submarine-borne_aircraft seems on point... $\endgroup$ – DJohnM Jul 3 '18 at 3:26
    $\begingroup$ "Submarine aircraft carrier", Wikipedia. $\endgroup$ – Nat Jul 3 '18 at 4:04
91
Yes,
The HMS M2 had a single seaplane aboard that it was capable of launching.
Her 12-inch gun was removed, replaced by a small aircraft hangar, the work being completed in 1927. This could carry a small Parnall Peto seaplane, specially designed for the M2, which, once its wings had been unfolded, could be lowered onto the sea alongside by a derrick for take off. On landing, the aircraft was hoisted back onto the deck and replaced into the hangar.
In October 1928, a hydraulic aircraft catapult was fitted, to enable the seaplane to take off directly from the deck.
The I-400 class submarine was also capable of aircraft launches.
The type name was shortened to Toku-gata Sensuikan (特型潜水艦 Special Type Submarine). They were submarine aircraft carriers able to carry three Aichi M6A Seiran aircraft underwater to their destinations. They were designed to surface, launch their planes, then quickly dive again before they were discovered.
There are some more info blurbs here worth checking out about various submarine/aircraft creations.
  • 14
    $\begingroup$ "once its wings had been unfolded, could be lowered onto the sea alongside by a derrick for take off" Would seem that the aircraft was only stored on the submarine, not launched from it, although the OP would have to decide if it fits his definition of "launched from" or not. The Japanese one seems to fit the description though. $\endgroup$ – Ron Beyer Jul 2 '18 at 19:16
    $\begingroup$ Are you sure 12 inch isn't a typo? That's a big number for submarine guns. $\endgroup$ – Joshua Jul 2 '18 at 23:15
    $\begingroup$ @RonBeyer Putting a boat in the water is considered launching so putting an airboat in the water has to follow, though this is not what I was originally thinking. $\endgroup$ – Pilothead Jul 3 '18 at 0:52
    $\begingroup$ @Joshua not typo. These early 1920s era submarines had dive times of 5 minutes or less... They had to function as battleships. That 12-inch gun is actually the same gun used in Formidable-class battleships of the Royal Navy. $\endgroup$ – Nelson Jul 3 '18 at 6:11
    $\begingroup$ @Nelson "Dive times of 5 minutes or less" What do you mean by this? That it took them less than 5 minutes to submerge, that they could only remain submerged for 5 minutes, or something else? $\endgroup$ – Eric Hauenstein Jul 3 '18 at 13:51
24
Also consider the Japanese I-400 class submarine, that carried three Aichi M6A Serian bombers. Probably the most advanced aircraft carrying submarines ever built.
They entered service too late to have any meaningful impact, but the engineering that went into them was amazing for its time. Just designing a submarine that could carry a watertight aircraft hangar without the topside weight capsizing the submarine was no simple feat. They built preheaters for the aircraft engines into the submarine, so the submarine didn't have to linger on the surface while the aircraft warmed their engines.
There was a plan to attack the Panama Canal locks with torpedos launched from the Serian aircraft, but it was never carried out.
    $\begingroup$ note that the I-400 was already mentioned by Dave's answer. $\endgroup$ – Federico Jul 3 '18 at 10:25
  • $\begingroup$ Plus, the U-Boot-Klasse VII could launch a "Bachstelze" somewhere near the end of the war, too. $\endgroup$ – Damon Jul 5 '18 at 17:23
  • $\begingroup$ Also this (en.wikipedia.org/wiki/Japanese_submarine_I-25) the only bombs to be dropped by the Japanese on the continental US were dropped by a float plane launched from a submarine. $\endgroup$ – James Mundy Jul 8 '18 at 21:03
15
If you allow "airplane" = "unmanned aircraft"...then, jets!
There was Regulus 1
Submarine testing was performed from 1947 to 1953 at the Navy's facility at Naval Air Station Point Mugu, with USS Cusk (SS-348) and USS Carbonero (SS-337) converted as test platforms, initially carrying the missile unprotected, thus unable to submerge until after launch.
And Regulus II
...the only submarine launch was carried out from USS Grayback in September 1958
The air inlet on Regulus II always makes me think it's laughing for joy to be launched.
    $\begingroup$ Unmanned is ok. Air breathing propulsion is required. Rocket assist for takeoff is ok. $\endgroup$ – Pilothead Jul 3 '18 at 0:26
    $\begingroup$ I like these, but where is the submarine? $\endgroup$ – Pilothead Jul 3 '18 at 0:40
    $\begingroup$ The links explain that they were sub-launched. Edited to include. $\endgroup$ – Organic Marble Jul 3 '18 at 0:48
    $\begingroup$ @Pilothead It's docked at Pier 86 in NYC 😉 $\endgroup$ – Nick Jul 5 '18 at 13:09
13
If a kite rather than an aircraft qualifies:
German U-boats used a towed autogyro to lift a lookout/pilot to a more advantageous altitude (about 120 m). https://en.wikipedia.org/wiki/Focke-Achgelis_Fa_330.
The strategy increased the visible range from 5 nautical miles to 25 nautical miles. There is one recorded instance of a submarine detecting, attacking and sinking the Greek steamer Efthalia Mari on 6 August 1943.
If a hostile vessel was seen,
If the U-boat captain were forced to abandon it on the surface, the tether would be released and the Fa 330 descend slowly to the water.
I believe this might discourage reports of enemy warships by the pilot/observer.
Tomahawk cruise missle (Wikipedia) I got beat to mentioning Regulus, but the Tomahawk cruise missile has been launched from a submerged sub. A rocket is used to initially launch the missile. enter image description here (reference)
    $\begingroup$ And if you're going to complain about the "lack" of wings--those are wings on that missile. It just has a very high minimum airspeed and thus can use very small wings. They use a rocket booster to get them up to the speed where the wings will function. $\endgroup$ – Loren Pechtel Jul 5 '18 at 18:28
Yes.
Here is a wikipedia article about many of the designs:
https://en.wikipedia.org/wiki/Submarine_aircraft_carrier
Most seem to have gone out of service before the end of WWII, but a German submarine, the Type 212, is being designed to launch UAVs out of its mast:
https://en.wikipedia.org/wiki/Type_212_submarine (see the last paragraph in the "Weapons" section).
  • $\begingroup$ Unmanned is ok but toys do not qualify. Payload capability of the aircraft has to approximate at least a small person. $\endgroup$ – Pilothead Jul 3 '18 at 1:27
protected by kevin Jul 4 '18 at 9:20
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
