Just wondering if Southwest Airlines flight 1380 was retired and replaced with a different flight number following the uncontained engine failure and depressurization accident in April 2018?
1$\begingroup$ It would probably be helpful if you identified the accident in question. $\endgroup$ – user31680 Jul 2 '18 at 2:53
$\begingroup$ I just added a link to the Wikipedia article. $\endgroup$ – slantalpha Jul 2 '18 at 3:26
1$\begingroup$ Why not add a one or two line description so most folks will recognize it? $\endgroup$ – jwzumwalt Jul 2 '18 at 4:08
According to FlightAware, Southwest has not operated a flight with flight number 1380 since the accident flight on April 17. The flights with that number for several weeks after the accident were all been marked as cancelled in the FlightAware database; other flight numbers were used:
Southwest uses the same flight number for many flight segments in a day, but their flight schedule shows that flights from LGA to DAL leaving at around 10:30am are using the flight numbers 5227 (Sundays, 10:35) and 237 (weekdays, 10:45).
