Does any aviation authority have a recommendation of how long to listen after changing to a new frequency before making a transmission?
source
  • $\begingroup$ It depends upon the frequency. Normally you wait a few seconds on a non-busy frequency. On a class B approach frequency if you don't hear anything for a few seconds then you need to check your radio etc. $\endgroup$ – Prashant Saraswat Jun 30 '18 at 19:38
I was always taught:
  • Change frequency
  • Give it a good 3 count
  • If no one is talking, transmit
The FAA just advises a pause as per the AIM [4-2-1] but gives no time specifically
a. Listen before you transmit. Many times you can get the information you want through ATIS or by monitoring the frequency. Except for a few situations where some frequency overlap occurs, if you hear someone else talking, the keying of your transmitter will be futile and you will probably jam their receivers causing them to repeat their call. If you have just changed frequencies, pause, listen, and make sure the frequency is clear.
You will also learn to anticipate the flow. For example if you hear a controller issue something you should expect to hear the aircraft read it back. Once you get a feel for the cadence of chatter you will have even less issues.
| improve this answer | |
  • $\begingroup$ If you're on an arrival to Chicago or NYC during rush hour, you might spend 30 secs just waiting for any dead space at all to chime in. $\endgroup$ – John K Jun 28 '18 at 2:25
My EASA compliant RT theory book states listen in for at least 5 seconds.
Whether that's a hard and fast regulation or a rule of thumb isn't stated, but the idea is you listen long enough to ensure nobody else is talking before opening your microphone.
  • $\begingroup$ Thx - I appreciate the intuitive logic and reference +1 $\endgroup$ – jwzumwalt Jun 30 '18 at 8:44
