Can a turbojet jet or turbofan powered aircraft land and take off from water? How much clearence from the water surface would it need for its engines so that it does not suck up water?
11
Yes, they can.
In service today:
The Canadair CL415 is a turboprop water bomber with water landing capabilities (typically, water skimming capabilities, to skim across a lake and refill).
The Shin Maywa US-2 is the latest in a series of rescue/maritime patrol aircraft that have been in service for some time. The design uses the engines and wing of a C-130, with an interesting STOL feature: ducts that blow air across the top of the flaps so that they can be set at a more extreme angle for extremely short takeoff.
The Beriev BE-200 has seen limited production in Russia. It uses high bypass turbofans, mounted high and behind the wings to protect the engines from water spray.
From the Soviet era, were the ekranoplan sea skimmers, that flew entirely in ground effects. All were turbine powered.
In a prototype stage is the AVIC AG-600 in China. Powered by four turboprops, it appears to be an upsized copy of the Shin Maywa design.
A one-off production flying today is the Doriner DO-24ATT, essentially a WW2 DO-24 maritime patrol aircraft that was re-engined with turboprops. It is currently flown by Claudius Doriner's grandson.
Four turbine powered amphibious/flying boat aircraft that were developed but never saw service were the Convair Sea Dart, Martin SeaMaster, Saunders-Roe Princess, and Saunders-Roe SRA1.
  • $\begingroup$ The Do-24 ATT also has a new and much improved wing. $\endgroup$ Jun 24, 2018 at 17:55
    $\begingroup$ The question asked for turbofan or turbojet aircraft. All on your list except the BE-200 are turboprops. $\endgroup$
    – Pilothead
    Jun 26, 2018 at 0:07
  • $\begingroup$ Note that the concern is not about water spray. That problem is no worse for turbines than pistons, likely less. The concern is about vortex like this sucking the water from the surface, which is only concern for turbojets and turbofans due to their much higher mass flow through the engine. $\endgroup$
    Jun 26, 2018 at 19:01
Yes, if it's designed to do so. There have been several jet seaplanes over the years, and one feature common to almost all of them is that the engine intake(s) are mounted above the wings or high on (or above!) the fuselage (sometimes on an auxiliary pair of high-mounted stub wings) to avoid ingesting water.
Martin P6M (intakes - and engines - on top of the wings):
enter image description here (Source)
Convair F2Y (intakes on upper fuselage; notable as the only seaplane ever to break Mach 1):
Beriev Be-200 (engines and intakes mounted on top of fuselage):
There are a couple of interesting exceptions to the "intakes up top" rule:
  • The Beriev Be-10 had intakes on the sides of the bow, relying on spray fences to protect them from water ingestion; apparently, raised intakes were tested at one point, but found to seriously degrade the aircraft's performance.
  • The Saunders-Roe SR.A/1 had the intake for its engines at the tip of its bow, presumably in order to get air not yet contaminated by spray.
And, of course, in an emergency, even jets not designed for water operations can land on water if need be, although the plane probably won't be flyable afterwards.
