The more the thickness,the more the frontal resistance,hence the more the drag a thick airfoil will produce. Under cambered can help increase lift without increasing the airfoil thickness , therefore not creating as much increase in resistance or drag . ..which is more plausible for a slow ultralight,a thick airfoil or an under cambered airfoil?
Source: https://www.flitetest.com/articles/beginner-series-basic-aerodynamics
  • $\begingroup$ Under cambered is not a common expression. Please clarify! $\endgroup$ – Peter Kämpf Jun 21 '18 at 15:39
  • $\begingroup$ Ok..airfoil with inward curving shape of its undersurface @Peter Kämpf. $\endgroup$ – David Teahay Jun 21 '18 at 16:13
    $\begingroup$ There's no difference in crossection area for undercambered and cambered airfoil assuming the undercambered one was created by "carving out" the cambered one. It's not dependent exactly on thickness $\endgroup$ – Francis L. Jun 21 '18 at 21:17
    $\begingroup$ Frontal area* crossectional area changes, but frontal projection area is what matters $\endgroup$ – Francis L. Jun 21 '18 at 21:43
First of all, the thickness-related drag increase is small, especially for airfoils below 15% of thickness. Thickness by itself mainly determines structural efficiency and wing volume and is chosen on those merits. A very common choice for GA planes is 15% - 16% at the wing root tapered to 10% - 12% at the wing tip.
Next, much depends on the wing's bracing. A pure cantilever wing will be heavy but produce very little drag, so it is the obvious choice for faster aircraft; however, bracing the wing will lower wing mass and, therefore, induced drag. For slow airplanes, bracing the wing helps to reduce drag at low speed. But how much bracing is the best?
Clearly, early designs used too thin airfoils and went overboard with the bracing. Look at the picture of a replica of the Etrich Taube, a very popular plane of the pre-WW I period.
Etrich Taube in flight
Etrich Taube in flight. Note the truss below the wing and the many wires keeping it in shape (picture source).
Next, many low speed aircraft used two braces, one forward and one aft, and an airfoil of between 12% and 15% because this helps them to get most lift from a given area. Note that all use high-lift devices: Slats and slotted flaps are a must:
Westland Lysander
Fieseler Fi-156
Westland Lysander (top, source) and Fieserer 156 "Storch" (bottom, source). Note the very similar wing bracing and flat-bottom airfoil.
Multi-element airfoils are complex, so maybe it will be best to look at gliders and motorgliders for inspiration - or even human-powered aircraft. Also, the Reynolds number, which is determined by the size and speed of the aircraft, needs to be considered. As a very rough rule of thumb: If you only want to fly slowly and operate at a Reynolds number below 1 million, use a highly-cambered airfoil like the Daedalus sequence (DAE11 at the root, DAE21 mid-span and DAE31 at the tip). For more flexibility and Reynolds numbers above 1 million consider a camber flap and a glider-type airfoil.
  • $\begingroup$ I have an amazing book, called The Miracle of Flight by Stephen Dalton, which describes aerodynamics and flight mechanics by moving up the Re scale through the natural world to the man-made one. Wings start out super thin, more or less single surface (bugs, with Re down in the thousands or less, for whom the air is like motor oil), get thicker and thicker as Re goes up (birds, early a/c, conventional a/c wings), then get thinner again when the speeds get high. $\endgroup$ – John K Jun 22 '18 at 1:48
  • $\begingroup$ @JohnK: Yes, such a scale is very instructive. The smallest flying insects do away with conventional wings and have something resembling brushes for creating lift. $\endgroup$ – Peter Kämpf Jun 22 '18 at 6:44
  • $\begingroup$ Informative!.....+1k for answering a question no one was willing to answer... @Peter Kämpf $\endgroup$ – David Teahay Jun 22 '18 at 7:40
