I like to fly over rivers and lakes in my ultralight. One of the things that scares me the most is if my engine died, I might drown down in the depths of the water as I egressed out of my ultralight.
My Hy-Tek Hurricane has an aluminum front and rear spar, with a few spreader tubes, and then it has simple aluminum tube ribs which slide into pockets in the Dacron wing covering. This leaves nothing but empty hollow space inside 99% of my wing.
Has anyone ever thought of adding some lightweight durable air-filled balloons inside their ultralight wing to add buoyancy in case of a water landing which would almost certainly flip my tricycle gear ultralight? As it is, the wing has plenty of gaps in it which would allow water to rush inside and sink my plane. I don't know how long that would take, but I would rather not find out!
My aircraft weighs just slightly less than 254lbs. So I would need approximately 254/8 = 31.75 gallons of air to maintain a neutral buoyancy, and I would probably want to add another 30% or so to that to turn my ultralight wing into basically a flotation raft if I ended up in the water.
So does anyone have any good ideas on what to stuff inside my wing so my little "ultralight" doesn't turn into an "UltraAnvil" and sink to the bottom with me drowning next to it? If I crashed in the water, I figure I probably have a 50/50 chance of extricating myself from the wreckage without drowning right away, considering the impact will probably knock the wind out of me. It would be difficult, but I think I could do it. If I was at a full stall when I touched down I think I would survive, but would certainly flip upside down, then it would be a mad scramble while upside down underwater to get the safety belt off and yank my helmet and it's wires off and kick free.
But if I CAN get out, the next problem is that I am fully clothed with shoes, maybe a ski jacket, gloves, jeans, thermals, and everything else. I have had an unlucky experience of being fully dressed while flailing in the river before when I dashed out to rescue an R/C plane once, and it was very dangerous, and I nearly did drown (I will never do that again!).
It sure would have been nice to have a partially sunk ultralight next to me to hang onto! So I was thinking balloons, because that would be easiest. I could just inflate maybe 100 balloons or so and then stuff each of them up in the zippered inspection seams, 50 in each wing. The weight would only be maybe 8 ounces or so of all the balloons, and I can't imagine that they would hurt anything inside the wing. Is this a good idea?
    $\begingroup$ Do you sit above the wing or below it? $\endgroup$ Jun 14, 2018 at 16:58
    $\begingroup$ google.com/… $\endgroup$
    – jean
    Jun 14, 2018 at 17:21
    $\begingroup$ Go to a local pool and practice swimming in full gear. Keep in mind you can undress while in the water (you'll have to strip off the wet clothes anyway once on shore to avoid hypothermia). You could also use the stripped clothes as a makeshift flotation device by tying up the sleeves. $\endgroup$ Jun 15, 2018 at 11:11
    $\begingroup$ If you are flying over water, while not regulation, it would behoove you to have one of these on at all times. $140 is a small price to pay for floating, and you'd probably pay that trying to pack balloons in your wings or seal them up. You should also have a "quick release" seatbelt that comes completely off in one movement and works under tension (if you are upside down and hanging from it). $\endgroup$
    – Ron Beyer
    Jun 15, 2018 at 15:13
    $\begingroup$ @ivanivan its better to have a manual inflation when dealing with open cockpit aircraft. It is possible for him to get wet in the cockpit from condensation and actual rain and have the vest inflate by accident which could cause an accident unless it is a flight rated item. $\endgroup$ Jul 8, 2022 at 13:31
Not practical to put balloons in the wings. They would expand at altitude, messing up the wing profile. How would you control that?
The best option, possible if the fabric is reasonably impermeable, is to seal all possible ingress points in the wing, leaving a small vent hole at a point least likely to be submersed, like the wing root trailing edge. This will at least delay the sinking. You could use ripstop repair tape used for fixing tents.
That'll slow down the sinking process, giving you lots of time to get out. Then wear one of those compact inflatable vests that boaters use that drape around your neck that you inflate when needed, for swimming to shore.
Even better, with all the weight you would add with various other solutions, might as well get a set of Puddle Jumper amphibious floats. Might as well make it possible to land on water anyway. Problem solved.
  • $\begingroup$ I didn't think about the air expanding, lol. I never go higher than about 5000 or 6000ft, but I can imagine a balloon would get bigger! $\endgroup$ Jun 14, 2018 at 23:24
    $\begingroup$ Yes at 6000 ft the atmospheric pressure has dropped by almost a quarter from what it was a sea level. Some commercial aircraft use tape over rib lightening holes at the tip rib and any holes along the spar that go into empty spaces in the wing structure to delay sinking of the airframe if ditched. $\endgroup$
    Jun 15, 2018 at 1:03
    $\begingroup$ About the inflatable vest: never inflate it before you are clear from the aircraft... or you'll think whit it! $\endgroup$
    – Quentin H
    Feb 6, 2019 at 10:20
Literal balloons probably won't work well.
Balloons aren't safe, puncture-resistant flotation devices. Most will puncture if damaged. Also, their location is too far overhead for personal safety. Also, balloons leak, so you'd have to refill them every once in a while, which would be very tiring.
For personal safety, one option is getting a HEED, also known as Spare Air. They have a bad rep, but their initial purpose was getting out of a drowning helicopter, and that's where they do work. It does require a bit of training to use safely, but mitigates more risks than it adds.
Keeping the plane afloat would probably require something tougher than balloons. Sealed lift bags are flatter, easier to refill, and won't tear as easily. But the fuselage will still sink, and keeping it afloat gets into more unorthodox solutions with inflation, which add their own complications.
It's more important to make sure you have a PFD and signaling equipment yourself - even for a good swimmer, staying afloat for a long time is exhausting.
    $\begingroup$ Weight, complexity, risk of unintended inflation. Solution needs to be passive. $\endgroup$
    Jun 14, 2018 at 17:39
    $\begingroup$ You have a point. But I don't see how a passive solution could do all the work. Weight-wise, it's a few pounds. Inflated buoyancy devices are a standard solution even on modern airliners (for personal survival). $\endgroup$ Jun 14, 2018 at 17:54
    $\begingroup$ I would be extremely vary of scuba gear in a case like this. It only takes about 3 m (10 ft) ascent with held breath—which may easily occur in the state of panic—to get pulmonary barotrauma and that is often fatal. $\endgroup$
    Jun 14, 2018 at 19:30
    $\begingroup$ That's fine. It just has to not sink to the bottom right away, long enough to get out of it. $\endgroup$
    Jun 14, 2018 at 20:20
    $\begingroup$ @JanHudec The Spare Air is a rebadged HEED, specifically designed for escaping ditched craft. Adds its own risks, but it was deemed to reduce more than it adds. $\endgroup$ Jun 14, 2018 at 21:48
