18
Constant-speed propellers are far more efficient than non-constant-speed propellers, allow the engine to be made considerably simpler (due to removing the need to continuously adjust the ignition timing based on how fast the shaft is rotating at any given moment), and, unlike traditional variable-pitch propellers, don't require the pilot to manually adjust the propeller pitch.
However, according to Wikipedia, propellers with constant-speed mechanisms have considerably tighter restrictions on them than other propellers:
A pilot requires some additional training and, in most jurisdictions, a formal signoff before being allowed to fly aircraft fitted with a CSU [constant speed unit; the part of the propeller mechanism that makes it a constant-speed propeller]. CSUs are not allowed to be fitted to aircraft certified under light-sport aircraft regulations in the United States.
Given that a constant-speed propeller performs its pitch adjustments automatically, without the need for pilot intervention, and that constant-speed propellers perform better, not worse, than other propellers, why all these extra requirements and restrictions?
    $\begingroup$ Constant speed propellers have 3 knobs to control the engine/prop (Prop Pitch/Throttle/Mixture) where fixed pitch props only have 2 (Throttle/Mixture). Some aircraft simplify the CSP controls (pitch/throttle) into a single lever, but either way it is helpful to the pilot to know what to do if your propeller starts to run away. $\endgroup$
    – Ron Beyer
    Jun 13, 2018 at 18:48
    $\begingroup$ No, it is not "automatic" in that it does it all automatically. The pilot still needs to set the prop speed, engine speed (throttle) and mixture. The automatic part is the prop maintaining that speed, it still has to be set. $\endgroup$
    – Ron Beyer
    Jun 13, 2018 at 18:59
    $\begingroup$ @RonBeyer, slight correction: the throttle sets engine power – the speed is obviously the same for engine and propeller (well, for turbine engine with free power turbine not exactly, but they are still quite closely coupled there). $\endgroup$
    Jun 13, 2018 at 19:31
    $\begingroup$ @JanHudec Of course, but we all call it "throttle" :) $\endgroup$
    – Ron Beyer
    Jun 13, 2018 at 19:32
    $\begingroup$ @Sean, “vanilla variable-pitch propeller” is essentially a curiosity. It never became common, because the constant-speed system is just a couple more parts and pretty obvious. $\endgroup$
    Jun 13, 2018 at 19:35
4 Answers 4
24
The engine is the same, not simpler. There is one additional level of complication to the system -- the constant speed propeller has a number of extra parts.
The pilot needs to handle one more lever, selecting the speed. And needs more training in order to remember to put it at the right setting in various flight conditions -- not to mention how to handle an emergency when the constant speed unit falls (you need to prepare for every possible situation).
All in all, more training and more complicated systems sets up the requirements for restrictions.
  • $\begingroup$ And don't forget there is also "variable pitch" still used in Bananza, Navion, Grummon Goose, etc on engines like the Continental "E" series that is more labor intensive than a constant speed. A "variable pitch" is a constant speed without a governor. $\endgroup$
    – jwzumwalt
    Jun 15, 2018 at 5:14
  • $\begingroup$ Without a FADEC that is, right? $\endgroup$
    – Raffzahn
    Jan 6, 2019 at 20:24
  • $\begingroup$ @Raffzahn: agreed. With a Fadec there can be a single power level control for both engine and propeller. Diamond Aircraft and Piper are examples for new aircraft, I believe used with A1-burning diesels. But the majority of the fleet is still "old-style" with three controls. I am not in the loop to know how that effects training and requirements. $\endgroup$
    – ghellquist
    Jan 6, 2019 at 20:58
  • $\begingroup$ @ghellquist AFAIK not at all, at least not regarding FAA pov. $\endgroup$
    – Raffzahn
    Jan 6, 2019 at 21:43
13
I recently moved from a fixed pitch propeller (FPP) (cessna 152) to a constant speed propeller (CSP) (Piper Dakota). In the FPP scenario the engine RPM is controlled by the throttle only. High throttle means high RPM and high power/thrust. In the CSP scenario the engine RPM is controlled by the throttle as well as the propeller pitch. One important thing to remember while flying is that you don't want to redline the engine RPM. Thus various power settings are defined in the power settings table in the POH. Also, when you come in to land you need to remember to push the propeller back so that you will have maximum power available if you need it ( in case of an abort ). All this means that you need extra training to use the propeller control effectively and not to damage the engine in the process. In reality, if you want to go fast cruise at full power at a high enough altitude ( say 7500 ft), then you probably won't even need to touch the propeller control ( this is true for Piper Dakota, I can't say for other planes)
What jurisdiction is that? Who is the formal signoff satisfying? In the US, I went from flying a Cessna 150 with fixed pitch prop and 100 HP to flying a Cessna 177 with constant speed propellor and 180 HP, also fixed gear. No formal signoff was needed to satisfy the FAA, nor the insurance company that I used to insure the C177.
If I had gone to 200 HP, retractable gear, and constant speed prop, then a complex and perhaps high performance rating would have needed to be signed off. Also the insurance company would likely have required some number of hours to be flown with an instructor before being allowed to fly the plane solo.
So, just the constant speed prop alone should not be a driver for a formal signoff.
  • $\begingroup$ Good point. A lot of people think you need an endorsement because they got one when they learned to fly a constant speed prop. When I got my I got my high-power endorsement, I learned to use the constant speed prop at the same time. Likewise, most complex airplanes also have a constant-speed prop, so people getting their complex endorsement conflate the requirement. $\endgroup$
    – JScarry
    Jun 16, 2018 at 4:13
There are engine operating rules which govern the manipulation of throttle vs prop. Most commonly. When increasing power: 1) Increase Prop RPM, first. 2) Increase throttle, second. Then the opposite for decreasing power. This order of procedure is to protect the engine from preignition/detonation due to a sudden increase in Manifold Pressure at a low rpm.
When these restrictions were originally implemented, many engine manufacturers had models utilizing gear reduction of the prop, where the engine turned faster than prop rpm. Continental had an engine with a full 2:1 reduction. If the pilot used the more common rule for power increase/decrease, gearbox damage would occur as a result of sudden unloading and even negative torque (Backlash). In aircraft with these engines the procedure was the opposite. When increasing power: 1) Increase throttle, first. 2) Increase prop rpm, second. Then the opposite for decreasing power.
Going back a little further. Aircraft fitted with Hamilton Standard "counterweight" props had to be shut down in max pitch, so that oil would not cool and thicken inside the prop, pitch-change cylinder as it cooled.
A lot to remember for someone just transitioning from a fixed pitch prop, back in the day. Maybe there wouldn't be as much of a need for the restrictions in today's equipment.
