A 50 story building is planned in Santa Clara, CA three miles from the SJC 12R runway end. Such a building is at least 500ft tall and many such buildings are 700ft or more, is this legal? Nothing around it is more than 100ft tall. Taller than 200ft qualifies it at least as an obstruction.
  • $\begingroup$ Just as an interesting side note check out the story in my answer here $\endgroup$
    – TomMcW
    Jun 6 '18 at 2:15
  • $\begingroup$ @TomMcW The powerline story was pretty great. $\endgroup$
    – Pilothead
    Jun 6 '18 at 5:19
  • $\begingroup$ Can you add a source or background information for the building project please? $\endgroup$ Jun 6 '18 at 5:32
If it falls within the limits set out by FAA FAR Part 77 then its legal. You can find a nice breakdown of Part 77 here but you would need measurements more precise than what google maps is going to give you to be sure. Depending on the height the FAA may also require them to light the top of it. This is actually an interesting break down as the FAA is a federal organization and building approval generally comes down at the city/town/municipality level. If a building is approved for construction by a city one can assume it is legal to be built and that the city accounted for the FAA regulations. According to AC 150/5190-4A which quotes the Airport an Airway Improvement Act of 1982 it looks like its on the city to ensure that nothing gets in the approach path:
...Sec. 511 (a) SPONSORSHIP. As a condition precedent to approval of an airport development project contained in a project grant application submittted under this title, the Secretary shall receive assurances in writing, satisfactory to the Secretary that ... (4) the aerial approaches to the airport will be adequately cleared and protected by removing, lowering, relocating, marking, or lighting or mitigating existing airport hazards and by preventing the establishment or creation of future airport hazards; (5) appropriate action, including the adoption of zoning laws has been or will be taken, to the extent reasonable, to restrict the use of land adjacent to or in the immediate vicinity of the airport to activities and purposes compatible with normal airport operations, including landing and takeoff aircraft; ...."
In other words, the city needs to have zoning laws that keep the approach path clear. This is largely covered under the above linked Part 77 but generally speaking if the building has been approved its more than likely legal as per approved zoning laws.
A bit of a related story: you should not put it past people to build out of spite. A farmer once built a silo right off the end of Chatham Airport's runway to try and stifle traffic that he claimed was buzzing him while he was working. The silo is now gone and I cant find any info on what happened to it but this was also some time ago and I dont know what the regulations were when it happened.
And in some rare cases, if there is something in your way, an approach can be devised around it.
  • $\begingroup$ I already knew it qualified as an obstruction, but I couldn't find anywhere what that meant legally. Does it just need lights or is it prohibited? And do you know what happened to the silo? It's gone. $\endgroup$
    – Pilothead
    Jun 6 '18 at 6:22
  • $\begingroup$ Do you believe the site owners and architects are totally unaware of the airport? or are maliciously building an illegal building? It strains credibility to believe the building is illegal; if it were illegal, it wouldn't move past the artist's sketch. The better question is, Clearly, such a building is permitted: Why and how is it allowed? $\endgroup$
    – abelenky
    Jun 6 '18 at 12:36
    $\begingroup$ @abelenky Chicago tore up Meig's field in the middle of the night. Was that legal? $\endgroup$
    – Pilothead
    Jun 6 '18 at 14:25
  • $\begingroup$ @Pilothead I did some more digging and added a bit, hope it helps to clarify. $\endgroup$
    – Dave
    Jun 6 '18 at 14:42
    $\begingroup$ It's not unheard of for a City to issue a building permit without first having cleared the building through the FAA. This exact thing happened near Montgomery Field in San Diego although not directly in line with the runway, but in the traffic pattern. Big lawsuit ensued. Net result was the building had to be partially "de-constructed" and lowered a bit. The City maintained federal regulations were outside its purview and the developer "should have known" to check with the FAA. Developer said a building permit was supposed to include all regulations. Not sure who won. $\endgroup$
    – PJNoes
    Jun 6 '18 at 16:20
From Dave's part77 reference a precision approach surface has a 50:1 slope to 10,000ft out and 40:1 from there to 50,000ft out. Width is 1000ft at runway and 16,000ft at terminus.
The runway has a 1300ft displaced threshold plus just less than three miles to the building puts the distance at 17,000ft. 50:1 for 10kft is 200ft plus 40:1 for 7kft is 175ft which makes the approach surface 375ft high as it passes the building.
Surface width from center line at that point is 17k/50k*8k or 1000ft. The building looks to be 2500ft from runway centerline, so it is 1500ft from the precision approach surface edge. The side slope at that point is 7:1 for 1500ft or 214ft. Adding this to 375ft makes the allowable height about 590ft, so the building could fit below the limit for construction. It would have to be lighted as an obstruction. enter image description here
  • $\begingroup$ Yeah, looking at Google Maps and using the measurement tool, it appears that the building (if the pin location on the map here is accurate) is about a third of a mile from the extended centerline of the runway. As a side note, there are already several tall buildings that aircraft fly pretty close to on arrival into SJC from the South. $\endgroup$
    – reirab
    Mar 11 '19 at 19:24
Standard climb rate is 200 feet/nautical mile. So 500 ft at 3 miles, = 2.6 nautical miles, could see some slow climbing aircraft passing pretty near by.
The airport should be taking steps to work with the city planning board or AOPA or something to prevent future outcries from the building occupants over planes passing near the tower.
    $\begingroup$ It may be more critical on landing. $\endgroup$
    – fooot
    Jun 6 '18 at 15:33
  • $\begingroup$ Yes, it could interfere with IFR approaches. Course, they could always raise the minimums and make it a Circle to Approach landing. $\endgroup$
    – CrossRoads
    Jun 6 '18 at 16:42
