I have found only the description of this pattern with experimental graphs.Could anyone please tell me the mathematical formula required to plot the distribution?
3$\begingroup$ I'm a little unclear by what you the task. Do you think that you could perhaps include a pictures/figures of what you have got and what you're trying to get? $\endgroup$– ThunderstrikeJun 6, 2014 at 10:57
1$\begingroup$ Funny - answers are pouring in, and we have yet no idea how the pattern looks like. $\endgroup$– Peter KämpfJun 6, 2014 at 11:40
That's because that is the best way to have detailed and precise data: you either simulate (e.g., with Nastran-Patran or XFoil, as cited by Peter Kämpf in his answer) or build a [scale] model and use a wind tunnel. If you use a scale model, depending on the focus of the experiment, you will have to be careful (while scaling back up) not to damage your data: for this you have adymensional quantities to look after, such as the Reynolds number.
There is not one formula to do that, but rather a method that given the airfoil shape (and the angle of attack) will estimate the pressure distribution. This method was extensively used in the days before computers and FEM tools existed (for what I know SR71 is a notable example where this method has been used in the early phase of the wings design), but, for what I know, nowadays is seldom used.
The method is based on Conformal Mapping, in particular the Joukowsky transform or the Kármán–Trefftz for more detailed and general cases (see Sec. 4.2 of this pdf for a more in-depth explanation). This is a transformation in the complex plane that, from the airfoil profile that you want to analyse, will map it onto a circle.
You want to do this because the ideal flow around a circle is well known:
At this point you have to know that around an airfoil the air will have a certain amount of circulation and that the total flow around it is the sum of the ideal unviscous flow plus the flow induced by the circulation:
Image from MIT
For this reason, you want to compute the ideal flow around a cilinder that has a rotation speed equivalent to the circulation around your airfoil[*]:
and it turns out that we have some formulas for that (image above taken from this page).
[*]: note that you will have different circulations for different angles of attack.
Now, why did we do all this? Because once we have the flow around the rotating cilinder and we have the mapping from the airfoil to the cylinder, we "only" have to invert the mapping:
and we immediately have our flow around the airfoil.
And once we have the airflow, finding the pressure distribution is quite straightforward, thanks to Bernoulli (you have the velocity distribution and you can assume that the transit of the air around the wing is fast enough to be adiabatic)
$\begingroup$ Conformal mapping is the most simple way to arrive at an exact solution for the inviscid case. Joukowsky airfoils have a circular camber distribution, and the transformation becomes extremely complex when a specific airfoil is to be mapped. $\endgroup$ Jun 6, 2014 at 11:38
XFoil uses two ways of plotting pressure distributions, one with the chord coordinate on the X axis and the negative pressure coefficient $c_p$ on the Y axis, like that:
The dashed line is for inviscid flow (from the potential flow solver), the solid line for pressure with boundary layer effects.
Another version plots the pressure as arrows orthogonally on the contour of the airfoil, like that:
Please note that negative values of $c_p$ produce arrows pointing away from the airfoil, and positive values point towards the airfoil. In all cases, the formula for $c_p$ is $$c_p = \frac{p - p_{\infty}}{q_{\infty}}$$ $p$ is the local pressure, $p_{\infty}$ is the pressure far away from the airfoil, and $q_{\infty}$ is the dynamic pressure far away from the airfoil.
