The aerobatic aircraft I've seen don't have any flaps or air-brakes, besides they're taildraggers so I guess they usually have to do stall landing or three point landing but I don't understand how the pilot controls the approach speed or just how they slow down.
The same as any other powered aircraft would - controlling their descent with a combination of pitch and power.
Most small GA type aircraft don't have air brakes, spoilers etc anyway, so that's fairly immaterial.
I'd imagine almost any civil aircraft can be landed quite safely without flaps - it certainly forms part of the standard training syllabus for the PPL and you'd likely be expected to demonstrate a flapless landing on your skills test. The only difference is a slightly faster approach and more nose high attitude.
You can land all planes without flaps etc.. It's just the question, if it is a landing or an arrival
In crosswind situations, a lot of pilots prefer to do little to none flaps set, as the plane stays more controllable.
Btw. you can slow down the plane by pulling the nose up. Putting the nose down increases the speed. This helps to adjust the speed.
$\begingroup$ Just to elaborate for the viewers - it's not that flaps make the plane unstable, but less flaps allows you to more easily increase the approach speed which does make it more stable $\endgroup$– DanJun 4, 2018 at 12:02
$\begingroup$ @David That’s not how I was taught or how I fly. The purpose of flaps is twofold: increase the descent angle and reduce the stall speed. If there are gusty conditions, pilots will increase the approach speed by 10% and not put in the last notch of flaps. This gives them a greater margin over stall speed and less drag (the third notch of flaps mostly adds drag). A sudden gust of wind then wouldn’t inadvertently stall the airplane before the flare. $\endgroup$– JScarryJun 4, 2018 at 16:28
The plane slows down from aerodynamic drag. Level off above the runway ( also referred to as the "flare"), and wait - the plane will slow down by itself, as it does the wing creates less left, and the plane will settle down to the runway. Holding the nose up as that happens helps to create drag and slow it down.
