I have noticed this overhead instrument panel. It is convered by a transparent plastic lid with a small hole in the middle. Inside it has lot of switches. What is it supposed to do and who operates the same?
I couldn't find an exact picture, but the below image highlights the area where the panel is:
Image Source
(easamodul10.blogspot.com)
That panel you saw is the forward cabin circuit breaker panel. There is also an aft one.
It is used by maintenance personnel and cabin crew. For example if a toilet becomes inoperative, pulling the 'vacuum sys C/B' for 30 seconds might solve the issue.
  • $\begingroup$ Thanks. Is there an enlarged image where I can see the labels of the buttons. $\endgroup$
    – Firee
    May 30, 2018 at 9:37
  • $\begingroup$ @Firee - Here you go: i.stack.imgur.com/AMntU.png :) $\endgroup$
    – user14897
    May 30, 2018 at 9:45
  • $\begingroup$ Interesting. Didn't know passenger reading lights are controlled from here. Also, it is quite high up, can cabin crew reach it easily? I never saw anyone operating those buttons. $\endgroup$
    – Firee
    May 30, 2018 at 9:58
    $\begingroup$ The reading lights are controlled from the seats. That's the circuit breaker, it cuts the power supply to the reading lights -- sort of like the home circuit breakers. $\endgroup$
    – user14897
    May 30, 2018 at 10:12
  • $\begingroup$ @JeffreyBosboom - a cargo loading system, why not ask a new question? it is interesting and more people will see it that way. $\endgroup$
    – user14897
    Jun 1, 2018 at 7:53
