On many turboprop aircraft, such as the A400M and the ATR 72, it seems that the air intake tends to be placed below the propeller (images: Wikipedia):
Given that mounting the intake in a higher location helps reduce the risk of foreign object damage from ingesting debris into the core, why are the intakes still mounted below the propeller? Are the wings and engines already mounted high enough that the intake location doesn't matter when it comes to FOD, or does another issue (maybe accessibility for ground crews?) outweigh the risk of FOD?
