12
The Concorde did not have horizontal stabilizers or elevators. As a result, the pilots have to move fuel around the aircraft to trim it up or down, as sluggish and hazardous move.
Why did the design team chose not to use a horizontal stabilizer? Was it because of the understanding of supersonic aerodynamics and/or technology of the time? Or, was it due to some aerodynamic principles? If someone were to design the Concorde today, would they still use the fuel transfer method to balance the CG?
16
(Source: concordesst.com)
It does have elevators in the form of elevons at the trailing edge. A delta is effectively a tailless flying wing with a really long chord. Like any flying wing, pitch stability is achieved by down force generated at the local trailing edge by a control surface that does the same job as a regular elevator/stab, by applying down force to balance the forward pitching moment of the CG ahead of the centre of pressure (an airplane is really just a teeter totter with the C of G at one end and the elevator at the other).
Fuel transfer is used to keep the C of G in a sweet spot range to minimize trim drag, which is the penalty taken in generating the down force at the rear, so that the down force can be no more than necessary for adequate pitch stability.
As for why they didn't use a horizontal stabilizer, the reason is that the delta plan form with elevons provides the required stability and control in pitch and allowed the designers to dispense with a separate tail surface, greatly reducing the drag of a separate tail (not eliminating, because there is still a drag penalty from the elevons generating down force). Same reason anybody goes with a flying wing. Plus, you need lots of sweep for low supersonic drag and lots of wing area for high altitude efficiency, so a tailless delta fits the bill.
A limitation of this is a narrower CG range (a more limited forward CG than with a regular tail that is farther aft and has more leverage) because the elevons have a short moment arm, a limitation of all flying wings. The ability to transfer fuel to adjust CG would help with this and I think Concorde's modest passenger loading didn't cause the CG range issues that a normal airliner would have to deal with.
+50
As the manual shows, the Concorde's trim was conventional (and not by fuel transfer) and that the control surfaces shifted the neutral position as would be expected (here's a schematic).
Moving the fuel around is not managed by the pilots, rather the flight engineer. It's a long-term process that has to do mainly with the lift force shifting aft as the plane goes supersonic, and shifting forward again as it slows down. Resorting to an aerodynamic solution for the shifting center of lift was not acceptable:
To make the adjustment by aerodynamic methods as in the subsonic aircraft is not feasible because any deflection of flying control surfaces would have to be made throughout the supersonic cruise and would cause unacceptable drag (Concorde History).
Delta wings do not need a trimmable horizontal stabilizer (THS) by default since the elevons are far back from the CG and are able to control the pitch. There are few deltas with a tail, like the MiG-21, but that's for increased maneuverability since it's a fighter.
A list of 59 tailless deltas can be found here.
So, once the researchers and engineers concluded the delta wing is the best choice for supersonic flight in the Mach 2 regime, there was no need for a THS.
Hypothetically adding a tailplane
Concorde was meant to be economical (on paper at least). If the sizing remained the same -- the same number of passengers in the slender 2+2 seating -- then the addition of a tailplane would have reduced the main wing area (let's assume that offsets the weight of the added mechanical complexity). But the fuel capacity and thus range would have suffered. Now the Concorde is no longer a transoceanic plane.
If the range was fixed, then the payload would have suffered, considerably raising the fare (in 1980 a Concorde ticket cost £600 -- \$3,900 in today's money) and making the sales team job way harder than it already was (the sonic boom and smoky engines concerns).
    $\begingroup$ I'm not aware of any airplanes that use fuel transfer for trimming itself, it's more to allow the CG to kept near an optimal location to keep steady state elevator downforce to a minimum. It makes sense that Concorde would have to use direct adjustment of control surface neutral by changing the center of the feel force unit (usually a bungee spring) to change the hydraulically held hands free position of the surfaces. This means the trim would work like an airplane with tabs, where the control stick moves as you trim. With a trimmable stab aircraft, control column neutral never changes. $\endgroup$
    May 17, 2018 at 23:57
  • $\begingroup$ BTW there was an article in FLYING about 30 or more years ago by a Concorde captain about what it was like to fly. I recall that he said it was quite demanding on approach because the pitch stability in the landing configuration was low. $\endgroup$
    May 17, 2018 at 23:59
  • $\begingroup$ @JohnK - Correct. IMO the question is based on two incorrect claims. After a small talk with @ kevin in chat here, it seemed like that the trim-by-fuel claim is what is causing a confusion. Regarding Concorde in media, I really enjoy ITVV's 5-hour documentary. $\endgroup$
    – user14897
    May 18, 2018 at 0:05
    $\begingroup$ @JohnK, there was a long ITVV film where the pilots, and especially the flight engineer, talk and show a lot about flying Concorde. Much, if not most of the time FE spent during flight was managing fuel. In particular, he explained how much of a trim drag there would be if fuel were not transferred correctly. Very interesting film, perhaps the best of all the ITVV series. $\endgroup$
    – Zeus
    May 18, 2018 at 0:19
  • $\begingroup$ @ymb1, yeah, that's the one :) I didn't see your comment when I was writing mine. $\endgroup$
    – Zeus
    May 18, 2018 at 0:20
Because horizonal stabilators are there to balance the pitch moment from the main wing lift, which, in a conventional aircraft, (where the main wing center of pressure is behind the aircraft center of gravity), would cause the aircraft to pitch nose down. The horizontal stabilator at the tail creates a down force, which creates a nose-up pitching moment equal to the nose down pitch moment from the main wing. The down force at the tail is significantly less than the Lift from the main wing (but further away from the CG) so the moment is creates balances the Main Wing Moment. Realize that the above description is a simplification, as actually, all of the forces are actually pushing on each tiny little bit of surface area of the aircraft wings, fuselage, horizontal stablator, everywhere, and the description above is just an arbitrary way of splitting up the effects of all those tiny individual forces into a few major pieces, which are equivalent to what is really happening, so we can understand and talk about it all with some understanding.
On a Delta wing, without a horizontal stabilator, exactly the same thing is happening, but it is now the result of the distribution of all the tiny lift forces over the entire surface of the one single delta wing. Over most of the wing, except for near the trailing edge, the forces are pushing the aircraft up, nd because most of the wing is behind the CG, rotating the nose down. But the trailing edge of the wing is curved upwards slightly, so that far back from the CG, the forces on the wing are pushing the aircraft down with a smaller force, but much longer moment arm (further away from the CG, and this rotates the nose up by the proper amount to balance the nose down pitching moment from the rest of the forces forward on the wing.
