I recently watched the following video:
In the video there is a mention that there are 'dimples' visible on the fuselage of a Boeing 747, when it is on the ground. It then goes on to explain that once the fuselage is pressurised - the expansion helps to "smooth" out the dimples and it will be flat.
I am curious as to what the structural significance is for 'dimples' on the aircraft?
