Windows in aircraft create a weakness to the structure, that is why they are very small. I'm not asking about installing them in the cockpit, which would create safety pitfalls, but could the windows in the rest of the fuselage be replaced by cameras and LCD screens that provide real time images of the outside world that even passengers sitting in the middle of wide bodied aircraft can enjoy? This could even include a sky camera for night travel.
5$\begingroup$ I'm not sure that this is a dupe: the other question is about replacing the cockpit windows, whereas this one is about replacing the cabin windows. $\endgroup$ – Pondlife May 7 '18 at 16:56
2$\begingroup$ I think it's relevant given the two high profile incidents involving cabin windows recently. $\endgroup$ – EL MOJO May 7 '18 at 19:00
3$\begingroup$ @ELMOJO If you're referring to the recent uncontained engine disintegration, that by definition can risk causing all kinds of bad things to happen to the aircraft. That it happened to a window in one case (or even a few cases) is by no means a guarantee that it won't be a hydraulic system or critical control surface or control wiring the next time! The money there would probably be better spent at improving the ability of the engine cowling to contain the forces involved, than to try to mitigate the effects by making changes to portions of the airplane that just happened to be in the way. $\endgroup$ – user May 7 '18 at 19:25
12$\begingroup$ I, for one, would be rather upset to only have a simulated view of outside. I rather enjoy the window experience. $\endgroup$ – SnakeDoc May 7 '18 at 20:12
3$\begingroup$ Better to leave the windows but offer an upcharge for VR goggles with 360 degree cameras around the plane so it looks like you're just flying through the air with the goggles on. Then you could get really amazing views of the grand canyon or the rocky mountains or whatever (on cross country continental US flights - I'm biased). $\endgroup$ – Todd Wilcox May 9 '18 at 18:35
Emirates Airlines have recently launched their new First Class with a similar concept.
It is only available in First Class and I doubt it has much to do with the structural implications as of now, but that could change if the idea catches on.
The virtual windows are a feature on the otherwise windowless cabin suites along the middle aisle, and project a high-definition view of the outside using real-time cameras mounted on the plane.
Source: The Verge
33$\begingroup$ Going virtual and just mimicking traditional windows? They should have gone all the way and made it a full screen across the whole wall! $\endgroup$ – JAB May 7 '18 at 20:18
10$\begingroup$ @JAB That might be a bit disconcerting for the passengers. $\endgroup$ – user253751 May 7 '18 at 22:57
19$\begingroup$ Wait till they connect the whole-floor screen to the downward pointing camera. $\endgroup$ – Brian Drummond May 8 '18 at 14:48
4$\begingroup$ @immibis only if they had a really strong fan and good a/c unit installed to go with :) $\endgroup$ – ivanivan May 9 '18 at 0:50
4$\begingroup$ @ivanivan They typically do have a really strong fan and a good A/C unit installed. :) $\endgroup$ – reirab May 9 '18 at 14:25
Note that the windows are a safety feature: You need to see outside in case of emergency, e.g. to know which side of the plane is surrounded by flames, or how deep in the water you are. This is actually the reason why the inner lighting matches the outside conditions for take-off and landing and the window shades have to be open. Even worse, the potential rescuers need to see inside to know the conditions in the plane (flames, smoke, attackers, debris etc.), so you would need to have some system that reliably works both ways.
I don't see how your hypothetical plane would get certified with even more emergency features relying on electricity and on something that's basically an entertainment system.
3$\begingroup$ This is exactly what I was thinking... "what if there is an emergency and power get's cut and now greater issues to safety are created" $\endgroup$ – ggiaquin16 May 7 '18 at 20:31
4$\begingroup$ The opposite is true as well. Upon landing it's common for the flight crew to request you open the window shades. This is in the event of a fire/emergency inside the plane, responders can see in from the outside. $\endgroup$ – BruceWayne May 8 '18 at 14:40
$\begingroup$ Also, in case of an emergency, it is useful for rescuers to be able to see from the outside what's happening inside the plane. $\endgroup$ – vsz May 8 '18 at 16:10
Problem #1: What gets displayed on the screen?
While I'm aware of Emirates' recent 'virtual windows,' there is a big problem with this idea in general: what should actually be displayed there depends on the location of the viewer relative to the window!
This is not an easy problem to solve - and it's effectively impossible to solve for multiple viewers looking at the same screens. You simply can't make the screen show what different viewers looking at the windows from different angles should see, even if you know the location and orientation of each viewer. The only solution to that is separate screens for each viewer - i.e. VR goggles.
I haven't been in Emirates' new suite, so I can't comment on how it feels in their case in particular, but I imagine this would be rather jarring to the viewer, especially in a simulated window like the ones Emirates is trying to use. It would feel like you're looking at a flat image on a screen, not like you're looking out a window - because that's exactly what would be happening.
Why does this problem happen?
When I move my head in space or turn my head relative to a real window, I can see different things out of that window. In the example of the windows on the side of an airplane, if my head is behind the window, I can see in front of the flight path through the window. If my head is in front of the window and I turn my head to look back at it, I can see behind the flight path. If my head is directly beside the window, I can see the view perpendicular to the flight path. The only way to do this with a screen is to track the location and orientation of my head, as VR headsets do.
While VR-style head-tracking would be sufficient for a single viewer, what two different viewers will see - even when looking at the same part of the same window - could be completely different. There is simply no solution to this problem when both viewers are observing the same screen, even if you do head-tracking, as the image displayed on the screen would need to be different for each viewer.
Problem #2: How much does all of this gear cost (in both purchase and maintenance,) how much does it weigh, and how much power does it use?
In order to properly implement this idea (assuming you want to see the real environment of the aircraft on the screens and not just something made-up or recorded,) you'll need to install both a lot of screens on the interior and a lot of cameras on the exterior, as well as computer systems to process the camera input and display it to the users in real-time (and even more complicated computer equipment if you want to actually do head-tracking and get the displayed image right.) This will also likely involve a substantial amount of software, especially in the head-tracking case.
All of this adds up to a large development cost and also a decent manufacturing cost. All of these systems will also need to be maintained, with parts being replaced periodically, whereas a piece of glass in the side of the fuselage requires relatively little maintenance, the parts cost is relatively small, and the development cost isn't huge.
Furthermore, the biggest actual problem with real windows is the weakening of the structure that you mentioned and, thus, the added weight to strengthen the fuselage. This turns out actually not to be all that much extra weight, since the fuselage is designed such that the windows are placed between the ribs that bear most of the load. So, there's a very real chance that all of the screens, cameras, and associated computers will actually end up weighing more than what the structure with real windows would have otherwise weighed, negating any fuel savings. Furthermore, while windows require little-to-no power input, the same is not true for cameras, screens, and computers. This requires even more fuel burn for the power generation.
So the screen/camera system probably isn't much, if any, more efficient than the normal windows. Overall, I would guess the TCO is more.
Problem #3: Safety
It turns out that windows are actually quite important safety devices - and not just the ones on the flight deck. In the event of an emergency - either in the air or on the ground - the people inside the aircraft need to be able to look at what's outside the fuselage. Whether it be observing structural damage to the aircraft after something like an uncontained engine failure or looking for smoke, fire, leaking fuel, or other hazards outside the fuselage prior to initiating an evacuation, the ability to see outside is safety critical.
After a crash or ditching - say, something like Asiana 214 or U.S. Air 1549, there will not be anything generating enough power to run all of those cameras, screens, and computers and there's a significant chance that they'll be damaged beyond usability anyway. Now how are you going to see where the water line is on the aircraft or the burning engine or leaking fuel on one side in order to know which doors are safe to use for evacuation?
After an uncontained engine failure that blows holes in a bunch of things that ought not have holes in them - such as on Qantas 32 - it helps to be able to send a flight crew member to the back and actually look at the damage to see what the current state of the aircraft is. This is especially true when the computers are giving the flight crew a confusing and seemingly-endless stream of error messages due to all of the damaged systems. This allows the crew to plan the most safe way to get the aircraft back on the ground given the current state of the aircraft as quickly as possible. Perhaps this would still be possible with the screens and cameras in this scenario, but there's also a good chance the failure would have damaged these systems such that they wouldn't be useable. You can still more or less guarantee that you'll be able to see out of a normal window.
3$\begingroup$ I don't see the real issue with problem #1. So what if it's like looking at a screen. It doesn't have to exactly match the"analog" window experience $\endgroup$ – sudo rm -rf slash May 8 '18 at 1:55
3$\begingroup$ Actually there does exist a technology to mostly achieve this without using VR goggles: display with a lenticular sheet. Won't give you look from above/below parallax, but will work for left-right. $\endgroup$ – Ruslan May 8 '18 at 11:21
22$\begingroup$ @sudorm-rfslash I don't know about you, but I can look at an LCD screen showing "outside" any time I want, and it doesn't feel like looking outside. Flying is one of those things where you mostly have to just endure the experience until you get where you're going. Being able to actually look outside at real outside and see the world from above the clouds is one of the little things that at least makes the flight interesting. Replacing that with the same crappy monitor screens we all have at home is taking away one of the only special and unique things aboung being in an aircraft. $\endgroup$ – J... May 8 '18 at 11:32
3$\begingroup$ A screen image like that might be OK for someone in an aisle seat or in the center section of seats. But for someone who always tries to get the window seat like me, I think a relatively low-resolution picture of the horizon instead of a window would be deeply unsatisfying and unsettling. For starters, I wouldn't be able to look down at what we were passing over. It would seem phony, and it would make me feel claustrophobic. No thanks! $\endgroup$ – rclocher3 May 8 '18 at 18:16
5$\begingroup$ @sudorm-rfslash For people sensitive to motion nausea, having the outside view match the actual view angle is very important; the best remedy for motion sickness (including seasickness) is to fix your gaze on the horizon, so that what you see matches what you feel. $\endgroup$ – Chromatix May 9 '18 at 10:46
