In this answer, it's mentioned that
However, IR missiles (AIM-9 Sidewinder, AA-11 Archer, MICA IR, ASRAAM) do not emit any EMR that indicates they're incoming; they use a passive FLIR sensor to identify and track the heat source they were told to kill (they don't even require a radar lock; the seeker can be cued to a pilot's helmet, or it can be "uncaged" and will lock on to the most significant heat source in front of it).
Emphasis added.
Given this, is it possible, given some very bad luck, for a fighter jet to fire an IR missile, only for it to get turned around somehow (for instance, by some sort of momentary combustion instability in its rocket motor, or by some very bad turbulence) and end up locking onto and shooting down the jet that fired it?
