Is lift greater at the wing root of an horizontal wing,just like it's greater on a tapered wing?enter image description here
Well this is sort of definitional.
Generally speaking the idea of any sort of taper or shaping of the wing like the examples you posted above is to deliberately reduce the lift at the tips in order to reduce induced drag. In that case, no, the rectangular wing would be more even across the span - although there's all sorts of other effects that would likely come into play that would adjust that to some degree.
But really what you're asking about is the lift per span. If you really mean "is there more lift at the root" then the answer is "absolutely every time" for the simple reason that the lift force at the root is the lift force of the entire wing, whereas at the tip it's the force of only the tip. That's why the spars get thicker as you move in toward the root.
