Can anyone identify the fighter here in this picture taken from a Dornier-do17?
From: https://stukablr.tumblr.com/post/145040185970/a-pic-took-it-from-a-donier-do17-a-hurricane
    $\begingroup$ Note the link states its a hurricane. $\endgroup$
    – Dave
    Apr 29, 2018 at 21:51
    $\begingroup$ Sadly, many a German airman's last words. $\endgroup$ Apr 29, 2018 at 21:55
5 Answers 5
12
Relative thickness of the airfoil, thickness repartition over span, and low dihedral angle of the entire wing, tells it's a Hurricane.
In addition to @qq jkztd's very good answer, I'd like to add that the Spitfire never had a such a wide oil radiator under the fuselage. That to me was the dead giveaway that it was a Hurricane. Quite a durable but honestly lackluster fighter.
    $\begingroup$ Yes, all the silhouettes I can quickly find of Spitfires have the radiator under one or both wings, not under the fuselage. $\endgroup$
    – Chromatix
    Apr 29, 2018 at 17:20
  • $\begingroup$ Try looking at the illustration on the Spitfire Wikipedia page: all Spits had radiators under the fuselage, Hurricanes did not. $\endgroup$ Apr 29, 2018 at 18:01
  • $\begingroup$ @TimLymington that is clearly false - en.wikipedia.org/wiki/Supermarine_Spitfire#/media/… vs en.wikipedia.org/wiki/Hawker_Hurricane#/media/… $\endgroup$
    – egid
    Apr 29, 2018 at 18:29
    $\begingroup$ @Jihyun But fairly well on par with the Do.17, designed around the same time. Also it was way easier and cheaper to build than a Spit, which was significant with wartime resources and serious technical problems with the Spitfire. Spitfires simply weren't ready in numbers by 1940. $\endgroup$
    – Graham
    Apr 29, 2018 at 20:39
    $\begingroup$ @Jihyun Me too. :) But it's a bit like saying a Tornado wasn't a Jaguar, or an F-15 wasn't an F/A-18. It was state of the art at the time it was designed, but it eventually became obsolete. $\endgroup$
    – Graham
    Apr 30, 2018 at 16:54
It's a Hurricane. No Spitfire of any Mark had a radiator under the fuselage, whereas every Hurricane, from the prototype to the "Last of the Many" did. And that is NOT a carburetor (carburettor in British English) air inlet. Re the comment about the canopy, Mark I Spits had a narrow canopy. No framed greenhouse, but not blown out at the sides either. The earliest Mark I Spits had a canopy that effectively was just an extension of the windscreen. Later ones had a bulged top for more head clearance, but still had flat sides. Later Marks featured the "blown" canopy that was bulged on the sides as well.
  • $\begingroup$ Welcome to Av.SE! $\endgroup$
    – Ralph J
    Oct 14, 2018 at 4:39
It's a Hurricane. The radiator is on the fuselage, which means it is a Hurricane. On a Spitfire the radiator is on the right wing. enter image description here
Agree with qq jkztd.
Also the canopy. You can just about make out the lines (in profile, it looks like a greenhouse) plus it's narrower. A Spit's is more bulbous.
