This is one of 3 question in "series" - one question split up in 3 to better reward those responding about each aircraft. Other questions: Yak-131, L-159
A-10 is one 3 planes that are used in the ArmA 3 combat simulator, but its aerodynamics modelling currently lacks significantly. I'm planning on writing a short "essay" to developers regarding what and how can be specifically fixed in the flight model, but I'd like to back my research with some hard data. Specifically, I'm interested in any of the following:
- L/AoA
- D/AoA
- Side lift/SA (Slide angle)
- Max G/velocity
- Flight envelopes (like one below for F-15):
Torques can well be left out - it's not a full fledged simulator, but the above data can give quite a good estimation of high level characteristics already.
Are there any good sources on any of the above data? I've found some (see below), but the quality leaves a lot to desire. Low-mach data is good enough for me.
I understand this is a tall order, but, well, SE is for expert answers - maybe a wonder happens and someone here has it? :)
What I've found so far:
