19
In comments on the answer to a question about transonic speeds and control surfaces I came across this comment and I'm having a hard time understanding it.
If you increase the chord, lift goes up almost linearly and stability decreases, because now the wing's lift force has a longer lever arm in flow direction. By increasing chord, you decrease aspect ratio...
There are a few things I am not understanding, but I think they probably relate quite heavily, so I'm going to ask them together.
Firstly, what is the aspect ratio of the wing? Is that a reference to the incidence of the wing and how a longer wing would mean a larger percentage of the side of the fuselage is covered by the wing (as seen from the front)? Or am I way off the mark?
Secondly, why does increasing the chord length decrease the stability of the wing? In my mind a longer wing would mean that the craft is more stable because the airflow is being forced into line for a longer period of time.
Lastly, this all relates to how chord length is considered during wing design. Are there other factors centered on the chord length that should be considered when designing a wing? And do those factors change depending on the mission of the craft in consideration (eg., trainer v. cargo plane v. jumbo v. Mach 3 spy plane, etc.)?
    $\begingroup$ For aspect ratio, see: What dictates the aspect ratio of an aircraft's wing? $\endgroup$ – fooot May 23 '14 at 18:52
  • $\begingroup$ I'm no aero engineer but my gut tells me a longer chord decreases the stall angle of attack $\endgroup$ – ratchet freak May 23 '14 at 18:56
    $\begingroup$ @fooot Thanks for the link! @ratchetfreak() I guess we'll see, Peter Kämpf is making me feel like he's going to put some great answer up for this question so... we'll see :) $\endgroup$ – Jay Carr May 23 '14 at 18:57
  • $\begingroup$ @ratchetfreak lol, sorry, the second half was meant for you. The first half for fooot... $\endgroup$ – Jay Carr May 23 '14 at 18:59
14
During design, chord length will be the result of wing span and wing area, because those two are what the designer wants to set. To be more precise, he tries to set a certain wing loading, trying to minimize wing area (and weight) such that the wing creates just enough lift for the estimated aircraft mass in all design cases. Take-off, maximum altitude and minimum turn radius are the classics which drive minimum wing area.
Now I will focus on aspect ratio, because Jan has already answered the rest with his excellent answer. The higher the aspect ratio, the less the wing tips will influence the airflow around the wing. This means that the wing creates more lift for a given angle of attack, but also that the stall angle of attack is lower. The ratio of wing span to aircraft mass (called span loading) is the driving force for induced drag. However, wing span and aspect ratio will also drive wing structural mass, so you need to find a sound compromise between low induced drag and low wing mass.
What is induced drag? It is the consequence of creating lift over a limited span. The wing creates lift by deflecting air downwards. This happens gradually over the wing's chord, and creates a reaction force orthogonally to the local speed of air. This means the reaction force is pointing up- and slightly backwards. This backwards component is induced drag! The wider the wing is, the more air can be used for lift creation, hence less deflection is needed. Consequently, the backwards tilt of the reaction force is smaller, resulting in less induced drag for the same lift.
If you fly fast, there is a lot of air mass streaming past the wing per unit of time, so you need to deflect the air only slightly. Your induced drag is small. That is why induced drag changes inversely with air speed.
Now you know that for high speed at high density, induced drag is not important. If you design an attack aircraft which has to fly at low altitude, a low aspect ratio will help: The lift increase due to gusts is smaller than with a high aspect ratio wing, and the induced drag is manageable.
How the lift curve slope changes with aspect ratio in subsonic flow is shown in the simple plot below. For a slender body (aspect ratio $\approx$ 0), the gradient of the lift coefficient $c_L$ over angle of attack $\alpha$ is $c_{L\alpha} = \frac{\pi \cdot AR}{2}$. Please note that the red line is only valid for AR = 0! Then the lift curve slope increases up to $c_{L\alpha} = 2\cdot\pi$ for $AR = \infty$ (and zero airfoil thickness and no friction effect), as shown by the blue line. lift curve slope over AR
There are more influences, however. Dihedral means that the lift is tilted inwards, and the part which counteracts weight is only growing with the cosine of the dihedral angle $\nu$. Same goes for sweep: Sweeping means that the wing only sees a reduced angle of attack change. If you want to capture all effects, a plot will not suffice. Here is a table with formulas for most cases: Lift curve slope formulas
Nomenclature:
$c_{L\alpha} \:\:$ lift coefficient gradient over angle of attack
$c_{L\alpha\:ic} \:$ lift coefficient gradient over angle of attack in incompressible flow
$\pi \:\:\:\:\:$ 3.14159$\dots$
$AR \:\:$ aspect ratio of the wing
$\nu \:\:\:\:\:$ the wing's dihedral angle
$\varphi_m \:\:$ sweep angle of wing at mid chord
$\varphi_{LE} \:$ sweep angle of wing at leading edge
$\lambda \:\:\:\:\:$ taper ratio (ratio of tip chord to root chord)
$(\frac{x}{l})_{d\:max} \:$ chordwise position of maximum airfoil thickness
$Ma \:\:$ Mach number
Another consideration is wing volume: In most aircraft, the wing will hold most of the fuel, and a long-range aircraft needs big tanks. Sometimes, only choosing a lower aspect ratio will give enough wing volume for the required range. In order to keep induced drag constant, the span will be kept the same, so wing area increases with chord length. This has the added benefit of more lift, so less complex high-lift devices are needed. Since the structural mass of such a low aspect ratio wing with simple flaps is relatively low, the only disadvantage is the higher friction drag of this larger wing.
If maneuverability is important, wing span needs to be as small as possible. This reduces inertial moments and roll damping, so the aircraft can accelerate faster into a rolling motion and will reach a higher roll rate. This is extremely important in dogfights when the one who points his radar, gun and rockets at the adversary first will win. Here the chord is chosen for sufficient wing area at the minimum practical wing span.
Now we need to talk about viscous effects. Friction between air molecules and between air and wing. The ratio of inertial to viscous forces is expressed by the Reynolds number, and generally a higher Reynolds number means your friction effects go down, translating into less friction drag and a higher stall angle of attack. Especially for model airplanes, but also for gliders, it is sometimes better to reduce aspect ratio in order to gain absolute wing chord. The Reynolds number increases linearly with wing chord, and this can also be a consideration for choosing wing chord.
A normal wing has positive camber, and this means that the center of pressure moves forward with increasing angle of attack. Moment-wise, this means that the wing will create a stronger pitch-up moment when it pitches up. This makes the wing by itself unstable, and you need a tail surface to regain stability. Making wing chord longer will increase the unstable influence of the wing relative to the unchanged tail surface. This is why I said that increasing chord will decrease stability. During design, you watch for a size called tail volume. This is the area of the horizontal tail surface, multiplied with it's lever arm expressed as a multiple of the wing's reference chord. If you keep this constant while changing wing chord, your stability stays the same. But then you change your pitch damping, because this is affected by the square of the lever arm. Digging deeper will uncover more consequences, so I better stop here for today.
| improve this answer | |
    $\begingroup$ Every time I read one of your answers I feel like I should just bite the bullet and get a masters in fluid dynamics/wing design. I may have to read this another dozen times before I get it, but I'm enjoying trying to decipher it as best I can :). $\endgroup$ – Jay Carr Jun 10 '14 at 4:46
  • $\begingroup$ I'm going to need to write up a question on what the horizontal tail surface is, it would seem. I can see how you'd need to counter-act the increased moment created by the center of lift moving forward with a positive angle of attack...but I'm not quite understanding how it's done. $\endgroup$ – Jay Carr Jun 10 '14 at 4:55
  • $\begingroup$ Yes, please go ahead and ask. To answer this in comments is not as easy. $\endgroup$ – Peter Kämpf Jun 10 '14 at 19:03
  • $\begingroup$ What do the dotted lines represent in the wing planform pictures? $\endgroup$ – DrZ214 Jan 27 '16 at 2:20
  • $\begingroup$ @DrZ214 The quarter-chord lines. $\endgroup$ – Peter Kämpf Jan 27 '16 at 5:35
Aspect ratio is defined as
$AR=\frac{b^2}{S}$
where $b$ is wing span and $S$ is wing area. For rectangular wing that's the same as span to chord; using area in the definition side-steps the need to define average chord for more complicated wing shapes.
Some properties of the wing depend on it's area while other depend on the span:
  • Lift is proportional to area and square of indicated speed (dynamic pressure).
  • Induced drag is inversely proportional to span and inversely proportional to indicated speed.
  • Form drag is proportional to span, thickness and square of indicated speed.
  • Skin drag is proportional to area and square of indicated speed.
  • Wave drag is proportional to span, thickness and grows rapidly above drag divergence mach number.
  • Strength is inversely proportional to span.
For each wing there is an (indicated) speed at which the wing is most efficient as induced drag has reduced already and the other forms of drag didn't yet grow too large.
Since induced drag decreases with span, high aspect ratio wings have the optimal point at lower speeds and their total drag at that speed is generally lower. That's why gliders have wings with very high aspect ratio (very long). As the other forms of drag increase with span, for higher speeds, especially supersonic, lower aspect ratio is better.
Note, that all the speeds are indicated speeds. Indicated speed is dynamic pressure expressed as speed at which it occurs at sea level. But as density decreases with altitude, so does indicated speed. Therefore transport jets cruise at modest indicated speeds and can have relatively high aspect ratio wings.
The other consideration is strength. Making long wing strong is difficult, so aircraft that need high manoeuvrability (aerobatic and fighters) can't have wings with high aspect ratio.
As for stability, during normal flight position of centre of lift along the wing chord is relatively stable. But there are three conditions that change it:
  • Stall. Pre-stall lift has centre of pressure about quarter chord, but post-stall lift has centre of pressure midchord. The resulting down pitching moment is a good thing in this case.
  • Mach tuck. This is flow separation caused by shock wave forming on the upper surface of the wing as the aircraft approaches speed of sound. The effect is the same as stall, except this time the down pitching moment is bad thing, because further increase of speed is not desired in this case. Supersonic aircraft usually have all moving horizontal stabilizers to have enough elevator authority to compensate for this change.
  • Extension of flaps. These also shift centre of lift more aft and create down pitching moment.
All these effects will be more pronounced in long chord - low aspect ratio - wings.
    $\begingroup$ Excellent, thank you, great explanation of Aspect Ratio...had to read it 3 times, but I think I've got a much better grasp of it now :). $\endgroup$ – Jay Carr Jun 10 '14 at 4:36
