The control tower of a certain airport with true altitude of 2000ft informs the pilot that QNH is 900hPa and the temperature at the airport is -10 degrees Celsius. The airplane is at FL300 (vertically above the airport) and the OAT measured by the airplane sensor is -30 degrees Celsius. What's the true altitude of the airplane?
The teacher gave us the following formula
$$Z_v=Z_{QNH}+(Z_{QNH}-Z_t)\frac{4(T_v-T_{Std})}{1000}$$
but the question is. We have the $Z_t$ (2000ft) and $T_v$ (-30 degrees Celsius), we can calculate the $Z_{QNH}$, but what is the $T_{Std}$ ? Is it the temperature at the flight level considering the ISA Atmosphere or do we need to start with -10 degrees Celsius and calculate the temperature at FL300?
