I think I understand both engine types, but I am just wondering am I right in saying that the only difference between the two types of engines is the bypass air (i.e. a turbofan is just a turbojet engine with bypassed air).
If not, what are the other differences between the engines apart from the bypassed air?
Any help on this matter would be much appreciated.
    $\begingroup$ Might help aviation.stackexchange.com/questions/4966/… $\endgroup$ – Ali Erdem Apr 8 '18 at 22:11
    $\begingroup$ Well, sort of correct. If you bleed some meaningful amount of air as bypass from a turbojet's compressor then it's by definition an also a turbofan. Quite a few turbofan engines has ultra small bypass ratio like 0.2x, some of which was indeed an originally turbojet design modified to bleed some bypass. Low bypass turbofan is indeed very similar to turbojet. $\endgroup$ – user3528438 Apr 9 '18 at 0:45
  • $\begingroup$ this anwser might be useful. $\endgroup$ – Manu H Jun 11 at 19:58
You are right about the bypass being the same result as a tubofan. However the word turbofan refers to an extra turning bladed wheel in front of the compressor and larger in diameter it turns slower and moves air past the engine on the outside.
| improve this answer | |
