I'm having an internal debate on interpreting the Class D ceiling in part of the the Memphis TAC. My understanding was in the case of a Class D under a Class B shelf, the ceiling of the Class D ends at the floor of the Bravo, or in this case: 1,800ft MSL.
However, the [29] box printed inside the area of the Class B/D is causing confusion. Is this explicitly stating the Class D does extend to 2,900ft MSL or does it end at 1,800ft MSL as I originally thought?
  • $\begingroup$ As has been noted in a comment, this question could use some clarification to indicate that you are only asking about the part of the Class D airspace that is charted as appearing to underlie a Class B shelf with a 1800' MSL floor (if you are). However, I see you have not been active on ASE since this question was posted, so... $\endgroup$ Apr 16, 2021 at 23:05
  • $\begingroup$ PS I think the fact that they chose to put the boxed "29" numeral in the western part of the Class D airspace rather than the eastern part is of no consequence whatsoever. $\endgroup$ Apr 16, 2021 at 23:07
The Class D airspace surrounding the Olive Branch airport extends upward to 2900 feet msl, excluding the Class B airspace. So, your understanding is correct.
Here is the official description of this Class D airspace from FAA Order 7400.11, Airspace Designations and Reporting Points: (emphasis is mine)
ASO MS D Olive Branch, MS Olive Branch Airport, MS (lat. 34º58'44"N., long. 89º47'13''W.)
That airspace extending upward from the surface to and including 2,900 feet MSL within a 4-mile radius of Olive Branch Airport; excluding that airspace within the Memphis Class B airspace area. This Class D airspace area is effective during the specific days and times established in advance by a Notice to Airmen. The effective days and times will thereafter be continuously published in the Airport/Facility Directory.
AMENDMENTS 04/15/04 69 FR 5009 (Added)
    $\begingroup$ Three are two different class B shelves involved. The one directly over OLV doesn't start until 3000. So the D ceiling is 2900 there. But the section of B closer to MEM are down to 1800 ft, so the D ceiling drops down with it to <1800 ft $\endgroup$
    – TomMcW
    Apr 2, 2018 at 17:56
    $\begingroup$ I used to teach out of KOLV, and the only NASA Report I've ever filed was for accidentally busting the MEM B airspace. So I will concur. If you fly west of Olive Branch, you better be low. $\endgroup$
    – Shawn
    Apr 2, 2018 at 20:11
  • $\begingroup$ This answer is not inconsistent w/ the comment from TomMcW, but it could be clarified to make the point more clearly-- $\endgroup$ Apr 16, 2021 at 23:08
