Strangely enough, I'm having trouble finding the unit reported by ADS-B on the Internet. Many sites simply refer to it as "ground speed". Is it measured in KPH?
2$\begingroup$ FWIW, I googled "ADS-B goundspeed readout". The second entry that came up was for faa.gov/documentLibrary/media/Advisory_Circular/AC20-172B.pdf. In that document, the only unit I saw for distance was nautical miles, and the only unit I saw for speed was knots. $\endgroup$ – Terry Apr 1 '18 at 21:15
ADS-B* encodes the ground speed in NM/s (nautical miles per second) in $2^{15}$ increments of ≅ 0.22 knots each such that:
0 ≤ Ground Speed < 2 NM/s
As of June 2015*, it is optional to report the ground speed (users can use two position reports to get the speed). Decoding to Knots (NM/h) is more common though for aviation for most of the world.**
* Eurocontrol Standard Document For Surveillance Data Exchange
** ICAO (Annex 5) recommends km/h but permits the 'temporary use' (as they put it) of non-SI alternative units for vertical/horizontal distances and speed.
