I'm a government teacher in school, currently I made an RC aircraft and flew it, now I'm working on a single engine light weight aircraft, I want to use a Honda CG 125 (single piston) engine, with 64" propeller 3 blade, engine RPMs are 3000, wings length is 29' feet and width is 4'6" approximately, and the length of aircraft is 20', empty weight of aircraft is 130 Kg, gross weight will be 250 Kg.
I want ask you: will this climb?
