28
I've just stumbled upon Why don't El Al 747's stay at the gates at JFK? in the hot topics. I kind of get why El Al decided to put missile defense systems in their planes but I was wondering: How common is this? Are there other airlines who do this?
    $\begingroup$ Obligatory: I could tell you but then I'd have to kill you. $\endgroup$ Mar 27, 2018 at 15:24
  • 7
    $\begingroup$ The day my inabillity to properly read a Wikipedia article made it to over 2k views... $\endgroup$ Mar 27, 2018 at 16:01
29
It's far from being common. The following carriers use missile defense on all or part of their fleet:
  • El Al
  • Israir and Arkia "can be assumed" to use the laser-type from Elbit (flightglobal.com, 2009).
While Elbit has not identified any of the carriers likely to receive the equipment, a source familiar with the agreement says "it can be assumed" that all three major Israeli airlines - El Al, Israir and Arkia - are in line to be fitted.
  • FedEx uses Northrop Grumman Guardian (Wikipedia).
Missile defense systems are also reportedly installed on some VIP business jets.
Further reading:
Related: How does the Guardian counter-MANPADS system work?
  • $\begingroup$ Comments are not for extended discussion; this conversation has been moved to chat. $\endgroup$
    – Federico
    Mar 27, 2018 at 15:45
  • $\begingroup$ If I'm not mistaken Fedex only equips a few aircraft which are used to fly into 'unsafe airspace' under their military charters. Not all aircraft are equipped. $\endgroup$
    – Anilv
    Mar 28, 2018 at 6:05
