I read an autobiography about Vicki Van Meter, who, with her instructor, flew across the United States at age 11 in 1993. Why could someone of that age not drive with the instructor? Does it have to do with a different set of principles that flying has as opposed to driving?
16$\begingroup$ There's a lot more drivers than pilots. If you let one 11 years old drive in the streets soon where you got thousands more and it will create a huge safety problem. And maybe more important, to become a pilot you do need a lot more commitment than to learn how to drive $\endgroup$– jeanMar 19, 2018 at 11:19
20$\begingroup$ Vicky was not Pilot in Command. $\endgroup$– Paul OgilvieMar 20, 2018 at 10:47
7$\begingroup$ @CrossRoads Please don't post answers as comments. $\endgroup$– David RicherbyMar 21, 2018 at 14:44
1$\begingroup$ 2D space is much more crammed with moving objects and obstacles than 3D space. $\endgroup$– JensMar 21, 2018 at 20:13
1$\begingroup$ @SteveKuo - It depends on your jurisdiction, obviously, and in many it may not be clear. In mine, for instance, the Road Traffic Act 1988 Section 87 says "It is an offence for a person to drive on a road a motor vehicle [...without...] a licence authorising him to drive a motor vehicle" (and similarly allowing a person to so do is also an offence in the same section). As you cannot acquire such a licence legally until you're 17, then "driving" on a road is not legally possible. ... $\endgroup$– JulesMar 23, 2018 at 21:05
Short answer: the US government agreed with you 3 years after her record flight.
In the FAA reauthorization act of 1996, the following clause was added to 49 U.S. Code § 44724 - Manipulation of flight controls:
(a)Prohibition.—No pilot in command of an aircraft may allow an individual who does not hold—
(1) a valid private pilots certificate issued by the Administrator of the Federal Aviation Administration under part 61 of title 14, Code of Federal Regulations; and (2) the appropriate medical certificate issued by the Administrator under part 67 of such title, to manipulate the controls of an aircraft if the pilot knows or should have known that the individual is attempting to set a record or engage in an aeronautical competition or aeronautical feat, as defined by the Administrator.
Per 14 CFR 91 (can't find the exact text right now, but I know this is true from my flight training), you cannot obtain a student pilot's license until age 14 (so, no soloing until then, let alone a long-distance trip) and a private pilot's license until age 16 (for gliders). You can't get a private pilot's license for your typical single engine aircraft until age 18. A sport pilot's license is possible by age 17, but is limited on the aircraft you can fly (that said, a coast-to-coast trip has been flown in a Piper J-3 Cub, which fits under the sport pilot license) and conditions you can fly in.
Hence, it would not presently be legal to do what Vicki did in 1993. According to a NY Times article covering another young pilot, Jessica Dubroff (aged 7 at the time of her fatally unsuccessful attempt at a coast-to-coast flight):
Jessica was breaking no aviation rules when she flew. The plane had dual sets of controls, meaning that the flight instructor was legally considered in charge and had the ability to take control instantly, though the plans called for Mr. Reid to take over only in an emergency. But within hours of the crash, Federal authorities announced that they would re-examine existing regulations on underage pilots.
This would have preceded the addition to the USC quoted above.
6$\begingroup$ Wasn't the FAA regulation change in response to someone crashing while trying to set a "youngest person" record? $\endgroup$– jamesqfMar 19, 2018 at 17:28
14$\begingroup$ @jamesqf: Yes. en.wikipedia.org/wiki/Jessica_Dubroff $\endgroup$ Mar 19, 2018 at 17:29
2$\begingroup$ Strictly speaking by the wording given, it wouldn't be illegal for an 11 year old to fly as long as they're not attempting to set a record or engaging in a competition unless "aeronautical feat" has been defined so broadly as to encompass flying a plane at all. $\endgroup$– PerkinsMar 21, 2018 at 0:28
2$\begingroup$ Agreed. I know of many private pilots who'll give temporary control of the aircraft to an unlicensed friend (while flying) under safe conditions, just so that they can "feel" like they are flying (usually means straight and level flight). The only CFRs I've found to say you can't do that apply to civil operations (14 CFR 121), air carriers (14 CFR 125), and flight with seating for 20+ pax/or an aircraft with payload capacity >6,000 lbf (14 CFR 135). $\endgroup$– MariusMar 21, 2018 at 1:13
4$\begingroup$ That is an absurdly narrow regulation. And doesn't actually answer the question, as it is still possible for somebody to repeat the feat in the question, as long as they are not attempting to break a record while doing so. $\endgroup$– JulesMar 21, 2018 at 8:54
I can't give an authoritative answer because I doubt one exists, but one huge difference between cars and planes is that all aircraft used for primary instruction can be flown from either seat. Both legally, and physically.
It's almost always entirely possible for a pilot to conduct an entire flight by themselves from the second seat, save perhaps some small logistical issues with the location of a switch or two.
To that end, it's not possible to fly in the front seat of a trainer without being at the controls. Therefore any passenger, in either seat, is sat in a position of being able to take control of the aircraft.
In addition to that, while aircraft are often designed with one primary seat in mind (normally the left hand seat), there are rarely any legal restrictions that say a training aircraft can't be commanded from the right.
This differs hugely from a car which, firstly, is designed specifically to be driven from one side or another. An instructor in the passenger seat may have a SUBSET of controls, but sometimes not and therefore can't fully control the vehicle from that seat.
1$\begingroup$ @Vikki Do those even exist? Simultaneous control inputs from two different people in a car sounds extremely dangerous. A fraction of a second of unexpected control inputs and you're run over by a truck or you've driven into a tree or concrete barrier at highway speeds. Airplanes tend to be much more forgiving than cars about fraction-of-a-second control inputs, except maybe when landing (and, I'd argue, probably even still then.) Airplanes react much more slowly to control inputs than cars do. $\endgroup$– reirabMay 26 at 21:39
$\begingroup$ @reirab: If you're instructing someone who's still learning how to drive, the more control you can take when necessary, the better. $\endgroup$– VikkiMay 26 at 21:41
$\begingroup$ @Vikki Not sure that I'd agree. Example: a deer jumps out in front of you. One of you instinctively tries to dodge hard left. The other instinctively tries to dodge hard right. Either would have worked, but instead you've run straight into the deer. Also, for city driving, replace 'deer' with 'person' and the results are the same. There's no time for coordination between drivers in split-second reactions like that. When flying, there's usually a lot more time and things tend not to jump out right in front of you (except for birds, at least, and there's isn't much you can do about that.) $\endgroup$– reirabMay 26 at 21:49
$\begingroup$ Also how would the mechanically even be possible? The controls in a car are basically a mechanical drive shaft $\endgroup$– CloudJun 6 at 11:27
Driving requires a much faster reaction time. Look at how the consensus process works inside a cockpit under healthy CRM. Just having a brief "My airplane" / "Your airplane" is far too slow for typical driving events.
Even if we set aside those formalities and simply have the Co-driver "leap in when needed", events don't unfold that way. Actually what happens is the Co-driver sees the emerging problem (truck pulling into their path) and the first thing she does is presume the Driver is going to handle it correctly. If the Co-driver leaps in too soon, 99% of the time she ends up needlessly wrestling the driver for control. So the co-driver intervenes quite late, only when it's clear the Driver isn't doing the job. At this point, usually, your goose is cooked.
A classic example of this was the first fatal crash of someone letting the computer drive: the co-driver was attentive and not watching a Harry Potter movie. Things unfold in rail operations slower than they do in cars, and yet still, discovering the driving mistake happened too late to prevent it.
All this to say... events in an airplane typically happen a lot slower, giving pilots a lot more time to use CRM to work solutions. Once the solution is agreed, the hard part - the use of judgment is done, and it's down to execution.
1$\begingroup$ Although the young pilot in the OP's anecdote did fly with her instructor present, I don't see anywhere that she was required to do so. If she could legally have flown without her instructor, this argument doesn't really apply, although I'm not sure if that's the case or not. $\endgroup$ Mar 19, 2018 at 18:16
2$\begingroup$ "Things unfold in rail operations slower than they do in cars" - that is also true of braking, which means that human reaction time is not always the critical point of failure there. $\endgroup$ Mar 20, 2018 at 15:05
1$\begingroup$ ^ What Piskvor said. Trains can take up to a mile to stop and do not have the luxury of turning like a car, let along maneuvering in 3 dimensions like an airplane. A train driver could be aware of an impending collision way before a car would even need to think about it and still not be able to stop it from happening. $\endgroup$– reirabMar 20, 2018 at 18:08
1$\begingroup$ @NuclearWang You can't solo an airplane (i.e. fly without your instructor) until you have a Student Pilot Certificate, which you can't get until you're 16. $\endgroup$– reirabMar 20, 2018 at 18:10
1$\begingroup$ @reirab: Indeed, in many situations it simply isn't possible for a train driver to become aware of an impending collision in time to prevent it (due to visibility-restricting things like tunnels and curves). $\endgroup$– VikkiMay 26 at 21:20
Regarding the comparison of the "set of principles that flying has as opposed to driving":
It's not necessarily the difference in the principles that matters; both kinds of vehicles have ways to control how fast you go and the direction in which you go, and in both vehicles it is possible to lose control (and sometimes also to regain control). But the principles of flight and the principles of driving are typically exercised under vastly different sets of conditions.
If pilots routinely flew along routes where there were solid obstacles just a few meters from the wingtips on either side (like the trees lining a country road) or if there were typically other aircraft flying in the same direction three seconds ahead of you and three seconds behind, and sometimes someone passing you in the same (or opposite) direction just a few meters away, I imagine the rules of flight would be somewhat different than they are now. But those are not the usual conditions under which people fly.
A very large part of the population drives, which means that a large part of the population consider themselves authorities on driving, and qualified to tell other drivers what to do. Far fewer people are pilots, which means that the average person more or less trusts the professionals to know what they're doing when it comes to flying. This results in different regulatory environments.
2$\begingroup$ Additionally, the same pressures mean that there is a much higher demand for driving instructors than flying instructors, which results in a necessity that becoming a driving instructor is easier than becoming a flying instructor. In many jurisdictions, the only requirement for being a driving instructor is having held a valid driver's licence for some specific number of years along with a clean record, but flying instructors are generally required to hold actual specific qualifications for the purpose. $\endgroup$– JulesMar 21, 2018 at 9:05
$\begingroup$ @Jules: Of course, given how much more dangerous driving is than flying, merely "having held a valid driver's licence for some specific number of years along with a clean record" is likely itself evidence that the person has the necessary skillset, eliminating the need for formal qualifications. $\endgroup$– VikkiMay 26 at 21:18
$\begingroup$ @Vikki that's incorrect, flying is massively more dangerous than driving. It only seems safer because of the huge effort made to make it safe. It's like saying "accounting for a large bank is easier than accounting for a child's game" simply because the children make errors more often than the bank. $\endgroup$ May 26 at 22:57
$\begingroup$ @Harper-ReinstateUkraine: Tell that to everyone in the comments and other answers who make the opposite point. $\endgroup$– VikkiMay 26 at 22:59
$\begingroup$ @Vikki Regardless, the safety doesn't "just happen", it happens because of enormous work done by pilots and maintainers Level that playing field. Train 100 people to drive a car and train 100 people to fly an airplane. All of them get exactly 8 hours of training that is comparable (not "classroom for cars, motion flight sim for planes"). Give them 100 each cars and airplanes maintained to an equal standard. They must take a 500km journey. Surely you must agree that if flying was safer than driving, that would mean the pilots would fare better than the drivers, yes? $\endgroup$ May 27 at 1:01
