During the flight it seems there is no smoke, it's only during takeoff. Here is an example
This question explains that smoke is caused by unburnt fuel but why is there so much more during takeoff?
Sign up to join this communityDuring the flight it seems there is no smoke, it's only during takeoff. Here is an example
There are a few reasons.
The first is that the engines run more efficiently when the aircraft is moving. As the aircraft moves faster, it's easier for it to get more air into the engine, which helps it run more efficiently.
The second reason is even simpler: like most aircraft a B-52 only rarely runs at full throttle. Most of the time that it's cruising, the throttles are backed off to just overcome the drag and maintain the current speed and altitude (though flying at terrain avoidance level is a rather different story).
The last reason is that the larger amount of smoke is largely an illusion. When the aircraft is moving, it's actually still generating close to the same amount of smoke. We're seeing the smoke from running the engines at full throttle for roughly a minute. During one minute of normal flight, it would generate somewhere close to the same amount of smoke--but instead of being concentrated in the 1 mile or so that we see here, it would be spread across something like 10 miles of sky. In addition, at altitude, you're a lot more likely to have much stronger winds, so exhaust from a minute ago will be relatively widely dispersed, rendering it much less visible than we see here (with air that looks like it's almost perfectly still).
This specific aircraft is a B-52H. The engines are identifiable as TF-33's which means we can rule out water injection as the cause of the smoke. Were this a G model or earlier it would be fitted with water injected J-57 engines and water injection would be the likely cause.
Since Water injection is not the cause I would suspect that you are looking at unburnt fuel. Bear in mind that in aviation redesigning components is not done capriciously because changing even the smallest detail can be extremely costly or dangerous (the military gets to pick one of those, civilians can only choose costly.) The TF-33 in the B-52H is a verstion of the JT3D engine which started life in 1958 and was not changed very much to create the variant delivered for the B-52H in 1961
Consider how cleanly the engine in this vehicle burns:
All early generation jet engine smoke like this at take off. This includes B707 and DC-8 and many other jet aircraft of the 1960's.
Most airliners today have more efficient engine that do not smoke. The B-52 still uses older generation engines. All these older generation engines were designed when fuel was cheap. They were far less fuel efficient and the black smoke you see is mostly un-burned fuel.
Just Google smoky jet engines at takeoff and you will see what I mean.
