What happens when you apply full throttle to the engines of a Boeing 787 at cruise altitude for 5-10 minutes?
Other than wasting fuel, what maximum speeds are reached?
Does that pose any danger or damage to the airframe?
Autopilot flying straight and level
Upon reaching the VMO/MMO the A/P will be inhibited from trimming down any further, which will result in the airplane climbing at the VMO/MMO.
Overspeed protection limits the speed to which the airplane can be trimmed. At VMO/MMO, the trim reference speed is limited by inhibiting trim in the nose down direction.
Hand flying straight and level
Pushing the thrust levers forward will result in a climb at the current speed due to the fly-by-wire design—only the trim buttons change the "trim reference speed".
Once the column forces are trimmed to zero, the airplane maintains a constant speed with no column inputs. Thrust changes result in a relatively constant indicated airspeed climb or descent.
Source: Boeing 787 FCOM chapters 4 and 9.
Further reading:
    $\begingroup$ So basically setting full thrust will put you in the coffin corner eventually rather than overspeeding? Interesting choice. $\endgroup$
    – Sanchises
    Commented Mar 11, 2018 at 21:10
    $\begingroup$ @Sanchises - Sure, if the crew want to ignore the caution light, the beeper, the autopilot EICAS message, and not having pitch command bars :) $\endgroup$
    – user14897
    Commented Mar 12, 2018 at 11:02
    $\begingroup$ You could hold a forward input on the control column to speed up beyond VMO/MMO instead of having the aircraft climb with zero control column force. $\endgroup$ Commented Mar 12, 2018 at 17:00
