Is military grade jet fuel more expensive than civilian grade? Why are governments moving away from military grade jet fuels?
1$\begingroup$ @fooot Not quite duplicate. The cost is not takled in the linked question (but yes all the other aspects of the question are answered there). $\endgroup$ – Manu H Mar 6 '18 at 19:21
$\begingroup$ Related: Why do military aircraft use a different kind of aviation fuel? $\endgroup$ – fooot♦ Mar 7 '18 at 18:31
Prices
Relative prices depend on what military fuel you compare to what civilian fuel. The current US Defense Logistics Agency pricing for jet fuels is as follows:
Fuel type $/gallon $/barrel
JP8 & JA1 2.15 90.30
JAA 2.13 89.46
JP5 2.18 91.56
- JA1 is "Jet A1"--normal, internationally available civilian jet fuel.
- JAA is "Jet A with Additives". It's Jet A (which is slightly less expensive than Jet A1, but available primarily in the US) with some additives added to improve lubrication, reduce corrosion, icing, etc.
- JP8 is the jet fuel the US military used for years before (semi-recently) switching to mostly using civilian grades. Basically Jet A1 plus some additives.
- JP5 is used primarily aboard aircraft carriers. It has slightly higher density than the others, and a substantially higher flash point (>= 60C, vs. >= 47C for Jet A1/JP8).
Summary
The military designations are mostly slightly more expensive than their purely civilian-grade counterparts. The prices given above are also somewhat higher than the IATA shows for pricing on jet fuels in the general market, at least at this moment1.
Why
Part of the reason for moving to civilian fuels is to reduce costs. Along with that, using something that's widely used and available makes it much easier to manage the supply chain, ensure an adequate supply, etc.
References
- Defense Logistics Agency FY 2018 Fuel Prices
- JP-8 and other Military Fuels (Warning: PDF)
- IATA Jet Fuel Price Monitor
1. At least as I read things, the price given by the DLA is intended to be used for budget estimates, so it presumably reflects their worst-case estimate of the average price during the coming year.
$\begingroup$ JA1 is formulated for colder environments than JA. Also some of the reason for having both military and civilian formulas goes way back to a time before either had a common standard so they each invented their own. Also military secrecy around any new tech may have played some role. having slightly different grades may also make investigating quality control and tracking sources and batch issues easier. $\endgroup$ – Max Power Feb 19 '20 at 23:03
