In recent years there has been ongoing debate as to whether or not increased reliance on auto-flight systems (autopilot, auto-thrust, etc.) in favor of manual flying proficiency has had a negative impact on safety.
Are there any data or objective examples supporting either position?
  • $\begingroup$ I think AA214 is a clear case where manual skills were incredibly deficient. $\endgroup$ – abelenky Mar 6 '18 at 15:29
    $\begingroup$ AF 447 is an objective case of the lack of standard flying skills leading to a tragic crash. $\endgroup$ – KorvinStarmast Mar 6 '18 at 16:12
  • $\begingroup$ @abelenky Is it possible the one you refer to is OZ214? $\endgroup$ – Cpt Reynolds Mar 6 '18 at 16:44
  • $\begingroup$ You're right: Asiana Air is OZ, not AA. My bad. (but I am unable to edit by comment) $\endgroup$ – abelenky Mar 6 '18 at 16:47
    $\begingroup$ I think it’s important to be aware that it will be comparatively easy to find a list of high profile cases where over-reliance on automation has had a negative impact, while the inverse scenario of automation „saving the day“ where human pilots would have had a high risk of committing errors will be much, much harder to compile. In order to comprehensively answer your question, both „sides“ will have to be balanced against each other, I believe. $\endgroup$ – Cpt Reynolds Mar 6 '18 at 16:51
The FAA certainly believes that manual flying skills are eroded in an airline environment, although to what degree is unclear. SAFO 13002, Manual Flight Operations, says:
Autoflight systems are useful tools for pilots and have improved safety and workload management, and thus enabled more precise operations. However, continuous use of autoflight systems could lead to degradation of the pilot’s ability to quickly recover the aircraft from an undesired state.
The SAFO is very brief, but there's a little more information in this document from the Air Carrier Training Aviation Rulemaking Committee (ACT ARC):
The Flight Deck Automation Working Group (FltDAWG) identified that the lack of practice with automation has contributed to the degradation of manual flying skills. European Aviation Safety Agency (EASA) safety information bulletin 2013-05 comments that continuous use of automated systems does not contribute to maintaining pilot manual flying skills.
That document references a 2014 NASA study called The Retention of Manual Flying Skills in the Automated Cockpit. Its conclusion was:
We found that while pilots' instrument scanning and aircraft control skills are reasonably well retained when automation is used, the retention of cognitive skills needed for manual flying may depend on the degree to which pilots remain actively engaged in supervising the automation.
The detailed analysis showed that motor skills are generally not degraded much (e.g. hand flying approaches) but cognitive (mental) skills like navigation and visualization are much more significantly affected:
Pilots sometimes struggled to maintain an awareness of where the airplane was with respect to the planned route, to reference their charts to keep track of what came next, to configure the airplane anew as they passed each important waypoint along the planned route, and to recognize and deal with instrument systems failures when they arose.
At least based on that information, it appears that the physical activity of manual flying isn't badly affected by automation, even flying on instruments. The risks that NASA found seem to be broader and related to mental awareness and alertness, including the ability to troubleshoot.
There are a few drawbacks to fully automated flight systems. High on this list are component and sensor failures, and eroded flight skills on the part of the pilots. Sensors do fail on occasion, which can either put the aircraft into a dangerous attitude, while the automated systems may lull the pilots into a sense of complacency and leave them unprepared to handle an unexpected emergency.
Consider these incidents in which automated flight systems played a significant role:
Air New Zealand acceptance flight, 2008. On an acceptance flight, when ANZ was reclaiming an A320 they had leased to XL Airways Germany, a frozen angle of attack sensor led to the aircraft stalling and crashing into the ocean after the auto flight system behaved unpredictably... ironically, while the pilots were testing the auto stall recovery.
AF 440... in this case, the auto flight system wasn't directly responsible. However, the combination of the auto flight system dropping out due to frozen pitot tubes, and an inexperienced flight crew, quite possibly with eroded basic piloting skills due to over reliance on auto flight systems, led to a high altitude stall and the loss of the aircraft and everyone on board. Contributing factors are the independent sidestick design (as contrasted to the directly connected center flight stick that might have alerted the pilot that the copilot had the stick all the way back), and auto-throttle not giving any visual cues that it had changed power input (as in moving the throttles).
Qantas 72 angle of attack sensor failure, sending conflicting signals to the flight control computer. The A330 didn't crash, but the pilots had to wrestle with the plane while it went through several extreme climb/dive cycles, until they could stabilize it. One crew member and 11 passengers suffered serious injuries, while 8 crew and 99 passengers suffered minor injuries. This could easily have been a fatal accident.
AF 296. This is the one that we've all seen the videos... while making a low flyby at a regional airshow, it appears that the A300's flight computer mistook this for an approach and went into a landing cycle and put the plane into a forest. In all fairness, this was an early effort at automated flight systems, and that particular issue has been resolved.
Air Inter 148 This was a combination of pilot error and the complexities of a fully automated flight system. On approaching Strasbourg, the pilots entered 3.3 into the flight system for descent, appearing to want a down angle on the nose of 3.3 degrees, when they had actually entered a descent rate of 3300 feet per minute... the flight computer was in the wrong mode. Contributing factors: the auto flight system actually increased the descent rate due to some turbulence encountered, and Air Inter had not installed a ground proximity warning system on their aircraft. Consequently, the aircraft flew into the ground. In this case, rather than eliminating human error, the automated flight control system appears to have encouraged it with a potentially confusing input method. The article notes that at least three fatal crashes of the A320 are traceable to confusion by pilots with the automatic flight control system.
These are a recounting of a few incidents in which the auto flight system played a role in a crash or near crash. It should also be noted that human error also played a role in the majority of them.
The flip side is - how many crashes have been prevented by auto flight systems? That's harder to predict.
I did find this article on airliner crashes per million miles flow, although some interpretation is required, as Boeing airliners have been flying for a lot longer than Airbus, and clearly the later versions of both have much better safety records than their earlier predecessors.
If we take two modern contemporaries that are heavily used today, such as Boeing 777 with some automation but a more traditional approach to cockpit and autopilot design, and Airbus A330 which uses a much more automated flight control system, we find that they have almost identical crash rates.
Right now, it would appear that fully automated flight systems versus semi automated is a draw... neither has a clear advantage.
