I'm on UA101 tonight, the very long IAH-SYD nonstop operated by United. If we look at Flightaware's routing for the flight (verified by the seatback moving map display) it's clear that we departed IAH, flew over El Paso and into southern California, left US airspace just west of Los Angeles, and then proceeded on the "normal" transpacific routing to Sydney.
Source: flightaware.com
What I can't figure out is why we specifically took this routing: it certainly appears that the point was to avoid overflying Mexican airspace, but I can't figure out why. United and lots of other US airlines provide service to Mexico so it's not like the airspace is off limits or anything. According to gcmap.com the routing we took tonight adds about 300 miles (~40 minutes) to a route that is already VERY long, and the 787-9 that we're on has to be very nearly at MTOW anyway, so adding another 40 minutes of fuel is on the heaviest (i.e. most expensive) marginal part.
The economics of airline travel don't usually allow for things like this - burning a few thousand extra pounds of Jet-A doesn't make for good business. Now obviously there's some reason for this routing, but I can't figure out what it might be. I also looked at a few of the other routings for this same flight, and just a couple of days prior the flight did take a more direct routing over Mexico on the way out.
The winds aloft didn't look meaningfully different - Foreflight computed the times as we'd expect, the "longer" one was ~40 minutes more ETE.
