What floatplane is this model?
enter image description here enter image description here enter image description here
(own work)
  • $\begingroup$ The pedant in me feels the need to mention that N679 is not a floatplane. Depending on period it is either a Standard J-1 or an Aerospace Quail. There are 52 current N-numbers for the G-44 not including the A model registry.faa.gov/aircraftinquiry/… $\endgroup$
    – user28387
    Mar 1, 2018 at 14:20
    $\begingroup$ @JuanCarlosVelasco, you have several questions like this, where you show views of a 3D model you say is your own work. If it is something you have done you must know the answer already, in which case you are using this site to showcase your own work. If you truly do not know the model then this cannot be your own work. I think it would be good for you to clarify the basis of your question. $\endgroup$
    – GdD
    Mar 1, 2018 at 15:28
    $\begingroup$ @GdD I assume he means the photography is his own work. $\endgroup$
    – fooot
    Mar 1, 2018 at 17:49
  • $\begingroup$ @fooot still there's a possibility the upload on SE is the work. $\endgroup$
    – user721108
    Mar 1, 2018 at 18:11
    $\begingroup$ @qqjkztd he seems to have started adding it after being asked to cite the images. $\endgroup$
    – fooot
    Mar 1, 2018 at 18:15
It's a Grumann G-44 Widgeon.
G-44 Widgeon (source)
