The combustion chamber of a jet engine may be can type or annular type. Annular type combustion chamber can be SAC (single annular combustion chamber) or DAC (double annular combustion chamber). What are the major changes between these two types of combustion chamber? Is the CFM56-7B26 a SAC or DAC engine?
1 Answer
See this answer for the difference between a SAC and DAC combustor. The EASA type certificate for the CFM56-7 also identifies which engines have the DAC and which have the SAC. The answer depends on exactly which -7B26 version you are referring to.
