I am currently training for my PPL. in the Cessna 182s we use I've only ever noticed two sets of ports for the headsets. If there were additional passengers in the back seats, how would they communicate?
The rear seats of a Cessna 172 has headset jacks, I imagine the 182 has the same.
You can see them in this picture:
You might also find them over the shoulder of rear passengers - as can be seen in this image (copyright attached)
That links the rear-seat passengers to the same intercom you're used to from a front seat passenger.
$\begingroup$ Pre 21st century the ports seemed to be an afterthought, I've seen them in various different places. In the roof, on the floor, & on the sides (as pictured). $\endgroup$– BDLPPLFeb 28, 2018 at 9:36
1$\begingroup$ @BDLPPL yep - Ive definately seen them on the ceiling. $\endgroup$– Jamiec ♦Feb 28, 2018 at 9:39
1$\begingroup$ I don't recall any of the C172s I rented having rear seat intercom. They were all 80s vintage C172Ps. $\endgroup$ Feb 28, 2018 at 17:25
It depends on the airplane and what year was manufactured in. Generally though the answer is yes. Most modern general aviation airplanes include headset jacks at all passenger seats. Diamond aircraft have the plugs for all headset jacks on the aft section of the center console. Cessna has them on the wall liners of the airplane. Many modern airplanes also will sell active noise canceling headsets included with the aircraft for all passenger locations. They provide active noise canceling to quiet the flight, intercom communications for all people on board the airplane and offer entertainment options such as Bluetooth connection with mobile devices and onboard XM radio.
While it's true that many "modern" aircraft designed for GA have passenger comm jacks, given that the average single engine GA plane is 40 years young, There are cases where they could be removed or INOP'd. Assuming that in the 182 in question there really isn't a set of rear ports for passengers, they would need to use a portable intercom box. These allow up to 6 occupants to communicate (pilot plus 5) and are often interfaced in some way with the aircraft communication system.
I've worked in the rear of a handful of PA-23s which had been "utility converted" (read been completely gutted rear of the pilot's seat.) Since the trim panels had been pulled, the ports went with them. We used an intercom box instead. There are a handful of boxes available with varying degrees of sophistication. Some for example, multiplex nicely with the airplane's com system to allow the pilot to make calls to tower while isolating passengers. Other models are simply a vox-compatible signal splitter.
I haven't been able to confirm this but I've been told that ultralights which take two occupants and glider trainers often use a comm box and portable transceiver to allow pilot/copilot/passenger to talk and be looped into ground comms without the need for any installed systems.
$\begingroup$ Not really the case that most GA aircraft have passenger headset jacks, or even headset jacks period. New ones probably (though I don't have the money to find out), but I think most GA aircraft were built in the '50s to '70s. The average age of a single-engine, 4-place plane is pushing 40 years, per this: generalaviationnews.com/2015/05/31/… $\endgroup$– jamesqfFeb 28, 2018 at 19:38
$\begingroup$ Fair point. Even though the air frames of many GA aircraft were designed 60 years ago the avionics tend to be a bit newer, no? Still, those of us who stick to the Cessnas and Pipers might not realize how many planes exist without such creature comforts as an intercom. All the more reason portable boxes need to exist. I guess "Many "modern" aircraft..." would be a more accurate statement $\endgroup$– user28387Feb 28, 2018 at 21:48
$\begingroup$ In my case, it is a Piper Cherokee, built 1966. Of course in my case the intercom is pretty irrelevant, since I very seldom fly with back-seat passengers, and not that often with a front-seat one. $\endgroup$– jamesqfMar 1, 2018 at 0:26
$\begingroup$ On the other hand, headset jacks aren't hard to retrofit. Drill two holes, screw in jacks and run the cables behind the sidewall panels. $\endgroup$ Mar 1, 2018 at 5:48
